92 SE-R shifter removal?
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
I'm trying to replace my shifter bushing. The front of the boot came off no problem; it's a standard nut, but the bottom part of the boot is something else.
I am not familiar with how to get these off.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
has to be removed from the underside of the car. remove heat shield above exhaust to get to the area.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
Oh, thank you! Also looks like an aftermarket shifter. Do those come with shifter bushings? Or are they directly attached?
RED_DET
Vendor
2011 Infiniti G37x
There is a bushing under there and mostly like it will be shot.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
The bushing was non existent! Snapped off those bolts when I was taking them off though. I hate drilling s*** out.
Thanks for the help though, can't wait to drive it!
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
Put it back together today and it's too stiff. You can't shift. I dunno what the deal is. I'm thinking use one bushing? But which one? Maybe pics will help you help me.
I didn't use the brass piece
Here it is installed
ABNRML4U
Car: Nissan B13
Nice to see a new shifter. LOL!
RED_DET
Vendor
2011 Infiniti G37x
I'm fairly sure this isn't where those go. What I meant is normally there is a bushing that is attached to the shift linkage underneath. Is this an aftermarket shifter?
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
I'm pretty sure it's a B@M knock off. There is a block style bushing underneath the shifter.
Where do you think these go?
RED_DET
Vendor
2011 Infiniti G37x
What brand are they and where did you buy them?
I'm thinking those go on the shift linkage which is shown in this pic, black bushings on right, hence the need for the brass sleeve.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
They're Energy Suspension. Got em' from here:
http://www.thepartsbin.com/sit....html
RED_DET
Vendor
2011 Infiniti G37x
THose bushings need to go like seen in the pic I posted.
The only other bushing I see people replace is this one:
You may have to cut one edge of the bushing off to allow for enough threads to screw the nut back on.
I just ordered one from autozone to replace in my car. The part number is 9.5101R. It came with two bushings and was $19.00.
This is what your shifter should look like, where is the collar that goes on top?
I just remembered you said it was an aftermarket shifter, that is your problem there.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
That's what I was thinking from the start. There is no such bushing for an aftermarket shifter.
I'll yank off the shift rod and replace that bushing soon enough and let you know how it goes.
mmm240
94 Toyota Pickup
03 Toyota Matrix XR
RED_DET wrote:
Yep, they go there. Still a bit sloppy though.
RED_DET wrote:THose bushings need to go like seen in the pic I posted.
Mine doesn't look like that. I think I'm just gonna leave it alone. It shifts, I'm happy.
