92 q45 crank position sensor location?
mjrsplat
Car: 1992 infiniti q45
I've got an issue with my 92 q45. I pulled the codes and it says the crank position sensor is bad, does anyone know where it's located? I cannot find it for the life of me. I've searched the fsm, alldata, etc and can't find any info on replacement.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
mjrsplat
As I stated in my first post, I searched the fsm and found nothing helpful
goody90q45
Car: 1992 Infiniti Q45 (sold)
It's mounted on the side of the engine under driver side engine shield and the mass air flow sensor. Looks like a distributor (because it is the engine's distributor). Try cleaning corrosion off the pins of the connector and CAS, tighten the connector pins and lube both sets with dielectric grease.
Q451990
:welcome: to NICO!
What is the actual code you're gettng? I suspect you're talking about the Camshaft Position Sensor, which we sometimes call the Crank Angle Sensor (CAS). The terminolgy changed at some point in the FSM.
Anyhow, it's located on the left bank of the engine below the intake tube and near the carbon cannister.
http://www.q45.org/checktiming.html
Heath
mjrsplat
I can't remember the code off the top of my head, but it was the code specific to the crank position sensor. 82 I believe? at ay rate, I'll check out the car tonight when I get off work, I'll post back if I have any issues locating it.
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
Results? Looking at this myself now
