kdkrone »
https://forums.nicoclub.com/kdkrone-u9295.html
Sat Jan 24, 2004 4:50 pm
q45tech,
Thanks for the info. After reading other threads that I was directed to I found your comments on OEM pads and will use them.
In one post you mention that your shop offers three different rotors: "factory, brembo, and powerstop drilled", to be exact.
Can you tell me what the advantages/disadvantages would be of these three? (I suspect that the factory rotors will be fine but I am interested to know what I could gain, if anything, from the others. My driving is city and highway, I am not particularly hard on the brakes [which amazed me when I found that the brake pads wore out so quickly when I first purchased the car--that has improved with subsequent pad materials], and the temperature in Fresno, CA varies from the 30's in the winter to 105 in the summer.)
Two quick questions: (I am going to check with the dealer as to whether they will mount parts that they do not supply, so that I can order from infinitipartsusa.com to take advantage of their discount.) 1, do I need to order a shim kit, i.e., do these need to be replaced or are they relative lifetime parts? 2, my front rotors are 1.030 and 1.045 and the rears are .310 each. Is there enough metal left to resurface or will these need to be replaced?
ThanksKen K
