adamAH64 »
https://forums.nicoclub.com/adamah64-u119548.html
Mon Nov 10, 2008 8:09 pm
Carmo,
The book told me that I had to remove them to loosen the rocker rods, but i was able to get that last valve cover screw out with a pair of needle nose pliers. That being said, I took off everything and replaced the belt. I also replaced my water pump while i was down there. Which brings me to my next issue:
I put everything back together in the correct order and lined all of the dots on the sprockets with the marks on the housings and the marks on the belt. I reinstalled all of the belts and pulleys and housing timing covers and it wont start.
I have confirmed that I have my number 1 piston in the TDC position with the rotor in the correct position. I have also confirmed that I have spark at the right time and I can even smell the gas coming from the tail pipe.
On a side note, when installed the new timing belt, the marks lined up, but after a few test hand rotations, the marks were off by one on each sprocket. I figured it didn't matter because they were proportionally off equally.
Now I'm stuck and frustrated.
Regards,The stationary man
