rn240sx »
https://forums.nicoclub.com/rn240sx-u12444.html
Tue Jul 22, 2008 3:39 pm
Well, after reading thru my 96 fsm (only one i could find closest to my 92) ive come to a stop and dont know what else to do.....
According to the fsm, when the ignition switch is turned to the ON position, the fuel pump relay will kick on for 5 seconds to build up pressure while the ecu is awaiting for the camshaft position sensor to send the 180 deg signal so that it can keep the fuel pump going. If the ecu does NOT see that 180 deg, the fuel pump stops running.
So i went to the fuel pump relay and went across the coil and turned the ignition ON and i got my 12V for approx 5 sec, then lost it..... GOOD
Then i went to the contact (throw side) and hit the ignition on again and got 12V going to the fuel pump... GOOD
Went to the fuel pump harness and disconnected it and went across pin 5 and had the wife hit the ignition switch on and i got my 12V for 5 sec and lost it... Then it said to check and make sure that i have GROUND at pin 6 and i did. GOOD
Then it said to go across the fuel pump itself at pin 5 & 6 and i should see .5 to 5 ohms short and i did.... i read 2.4 ohms..... GOOD
So it all checks out, im getting power to the fuel pump for the 5 sec it should until the motor turns over and the fuel pump is reading within spec and the motor is cranking and cranking but its not turning over....
So i removed the fuel feed line from the fuel rail, no pressure built up, leave the hose hanging and hit the ignition ON and no flow. turned ignition off and back on and also attempted to crank the motor over.... motor is cranking but no fuel is flowing or shooting out like a geiser....
But its weird all this checks out fine, but when i hit the ignition, i dont hear the pump moving upon 1st ignition hit... even laying down right there by the rear tire listening, and having someone hit the ignition... i dont hear the pump going for that 1st 5 sec.....
im lost......
