MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Mon Feb 26, 2007 3:31 am
Sure.If you make a baffle to separate the filter from the rest of the engine bay, make some piping for the straightest shot from there to the plenum, and use a high-flow filter, you might see some gains. The open cone filter should flow better than the stock filter in the more restrictive airbox. There's probably not a ton you can do to to straighten the shot from the fenderwell to the plenum, but if you open things up a bit, you could do some good.
Modifying the stock airbox and intake plumbing is another good route. It's fairly common and simple to do. It basically just involves removing all restrictions, such as lips inside the plastic piping that restrict airflow diameter, and also increasing airflow into the airbox itself.
