Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Wed Mar 28, 2007 4:05 am
No M30-specific experience here, but I suspect it's a lot like the Q and Maximas we have owned. The outer tie-rod is just screwed out of the tie rod end.
Cut the metal retaining band on the big side, then remove and replace. Since you'll be paying for an alignment, you might as well replace both boots at the same time.
Good luck!
Heath
