DCaff300ZX wrote:I see you mention a culprit, but just for the heck of it check the brake dust/debris shields which also can become close enough to the rotors to touch during turns, and also trap small rocks which can cause grinding and other noises. Have had both in my 14 years of Z32 driving.
Another possibility but only after collision damage or adjustable rear suspension upper control arms is the HICAS connector contacting the inside of the rear wheel/rim during turns, but without adjustable RUCAs out of adjustment range and showing extreme camber, only can happen with bent HICAS arm or bad HICAS arm ball joints. All worthy of inspection/consideration.
Yeah, I had to have the Rotors turned until I can get enough money to replace them, but we went through the entire brake system. We had the car on the lift and everything sounds fine, it's just during quarter turning you can hear what we think is the viscous coupler failing. The HICAS looks and seems to be running fine. We checked for loose control arms, and checked the camber, I need to adjust the camber a tad, but it's not crazy out of whack right now.
The hardest part is waiting on a good LSD to come up, doesn't seem like there are many of these LSD's left over. I want to check to see if any other LSD's would work, might be worth a shot.
