speeddemon72 wrote:Update: Pulled the timing covers off and the upper idler pulley was f***ed. The little bearings were everywhere. Is there a high possibility that the valves were bent? And also how do I realign all the cams and the crank. Im in a real learning process here and any advice is much appreciated. Thank you
Go under "everthing you need to know about the Z32" at the home page. You can open the Factory Service Manual and it has a step by step procedure to the timing belt. Honestly, if its your first time I would highly recommend either having a shop that works on these cars or someone that has done it before to help. These can be a PITA to do.
That being said, how are you with mechanics? An honest answer, everyone has different levels.
I would also recommend doing a 120k kit. If the top idler pulley is bad, the rest are not far behind. These kits are roughly $500, so be prepared for that. If you take it for a shop to do it, your probably looking at about another $400-$700 in labor dependent on shop prices.
Now for the valves, if it was at idle and how you described it, chances are low the valves were bent, but I have seen them bend at low RPM's so there is a possibility. Two ways you can find out. Take the head off or do a leak down test. Leak down test is easier and cheaper. You can see if a shop has a scope they can peek into the combustion chamber, but finding one that won't cost $100+ for them just to look is going to be tough or even finding one.
Is the timing belt still on the cam gears? If it is, there is a dimple or "dot" on the front of the cam gears. if you look at the plate behind the cam gears there is a dimple or "dot". These are supposed to line up, for the most part, and that is how the timing is aligned. All the cam gears and crank gear have them. If the belt is still on the cam gears, count the cogs of the t-belt from dot to dot and post the number of each of the following. Count it a couple times, make sure you have the correct number. Do each of the following
Passenger exhaust cam to Passenger intake cam-
Passenger intake cam to driver intake cam-
Driver intake cam to Driver Exhaust Cam-
It can be tricky and you may need to turn the engine to count. The nut is a 27mm for the crank pulley. Use a breaker bar and the 27mm to turn the engine. Do NOT use the starter, you could cause damage if you do. Remove to the spark plugs to make it easier. If you run into resistance trying to turn the engine, stop, do not force it. That means the piston is hitting the valve.
