ZR8D »
https://forums.nicoclub.com/zr8d-u250367.html
Wed May 13, 2015 8:50 am
Yes, I checked both. The regulator arms are good and I also checked the sprocket. Originally I thought it could be the sprocket, being the way the glass was hanging up. I thought for sure that a spline might be worn down and it was causing the hang up. Then again with a little less than 85,000 original miles on my Z, you wouldn't think a steel sprocket would be worn. But who knows... It's really aggravating trying to resolve the issue.
I usually do not work on my Z. Brett Ramey and Tim Davis usually tackle anything mechanical. Being they both are getting ready or are heading to ZDAYZ, I thought I would try my hand in fixing this small issue, which has turned out to be a nightmare.
