90 300zx charging problems
izxri91
Car: 300zx
    ok so I've had my z for almost a year. When I bought it. It had an obnoxious squeal due to the alternator being bad. So I recently replaced it. Fixed the problem finally had good voltage. Now since I've owned the car it has not had a tie down on the battery. Well after driving for almost a week and half with no problems. My dash lights up with the battery light, seatbelts,brake, abs. I pull over wiggle the terminal it goes away. Later it does it again. So I buy a tie down kit and new terminals put it in. Well still not charging. Tested my battery at work it's good checked my fuese by the battery all good. Am I right to assume my car hates me and I have to put another alternator in!? HELP ME LOLOL
    elecfus
    you battery terminal should be on so tight that you cant actually wiggle the terminal.
    wtfeezey1
    Car: Nissan 300ZX NA 2+2
    Have you tried cleaning the terminals and the connectors? might be a little corrosion underneath interfering with the contact.
    evildky
    Car: 71 Datsun 240ZT
    87 Nissan 300ZX N/A-T
    06 Nissan 350Z GT
    Toyota Tundra TRD RW
    And add on terminals suck, you're better off buying new OE cables, at last check they were still available.
