240ight »
https://forums.nicoclub.com/240ight-u25432.html
Fri Apr 22, 2011 1:31 pm
Hi peeps. Ok so here is the story. I hope you guys can help me. Car had been running fine but had engine light on. Emmission/inspection are due so I checked codes and it was injector leak. I checked all injectors and seemed fine so I reset code did a tune up and drove it a few days to see if light would come back on. So far no codes after about 200 miles so I took it to get the emmissions done. It failed and ever since then it has had a weird problem. It runs rough and missfires but the problem is intermittent. It can run fine for a day or two and then it can run and sound like s*** for a day or two. and lately its been worse. I start the car and give it gas and runs fine and then bugs down and then picks back up. It almost acts as if i was giving it gas and releasing and hitting gas and releasing.
When it runs and sounds fine everything seems normal. When it boggs down car has a bad knock and does not pull like normal engine, sound reminds me of the old "bug" engines.
Any Ideas on where to start checking? I truly appriciate any and all tips and help.
