9.5 width
alphapig
Car: Nissan Altima Coupe S 2.5
Hey guys,
Is anyone here running a 9.5 wide wheel?
What tire setup are you using?
I just ordered 18x9.5 +45, and I'm thinking of using 245/45/18
Any input?
Oilsink
Car: 08 dark slate
i was running a 18x9.5 +30 wheel, i was using 235/40/18's and it was a bit stretch on the tire but i had no issue rubbing on eibachs, u prolly wont rub with the offset being +45.
alphapig
Love those Rotas man.
I have 10mm spacers from my old wheels, so if there's clearance issues with the suspension I can put them back on.
Isn't 35 profile on a 18in wheel smaller than the stock diameter?
Oilsink
Car: 08 dark slate
alphapig wrote:Love those Rotas man.
well the 35 series profile is just 35% of how wide the tire is, so if its 225/35 its gonna be alot smaller on the sidewall (height) of the tire. The stock tires come with 215/60 so the sidewall is like 130 mm and 225/35's are 78 mm tall. if i understood the question right lolol.
alphapig
I'm comparing the full wheel + tire height.
Check this out:
http://www.1010tires.com/tiresizecalculator.asp
The overall diamater for stock wheel+tire is 664.21 mm
For a 45 profile tire it's 677.67 mm For 35 it's 628.65 mm
Basically your overall wheel diameter is a lot smaller than stock. Might be affecting your speedo.
Those Rotas would fill out the wheel gap nicer with a bigger sidewall too.
I remember you saying that you were upgrading to 19's tho, in which case a 35 profile tire gives roughly stock diameter.
mrodrig2
Car: 2008 Altima Coupe 2.5S CVT
You missed that he said 235/40 (not 35) which is 645mm od. He is a little small and the tire size you suggested is a little large. Either way, you will be off but really 2-3% is ok.
If you wanted to be closer than that - 245/40/18 or 235/45/18. Obviously the trade off is that some of these tire sizes are more widely available than others and vary in price.
