89 S13 w/ka24de Analog Cluster ISSUE!
tre4s13
Car: 89 Zenki s13 with a 94.5 DE swap.
I recently finished my ka-e to de swap.
Car started on first try (harr)
But the dummy lights are ****ed?!
Here's the problems:
Gas reads full on the needle, but the gas light is on. (i'm full but not full?! lol)
Speedo is dead
Tach is dead (swapped with dohc tach)
h2o is dead
And the lights flicker?!
I've wired it according to every tutorial imaginable pertaining to this swap. (the white plug)
It's not shorting behind the cluster....my dash was never on so i'm pretty sure when I held it in my hand...
And the wires from ecu to white plug are straight.
It definitely has something to do with the door switch. *shrug*
According to the FSM it says it's the Door Latch Switch (D11), before i plugged it back in the auto latch was in the closed position...once i plugged it in, it functioned properly. Then the fuel read a little over a quarter tank and the empty (dummy light went off). But when I open the door, it goes retarded?
Any help would be greatly appreciated, contact info in profile. And i'm ALWAYS online...
Thanks.
tre4s13
You would think SOMEONE would know something in this particular section...
