JayArr »
https://forums.nicoclub.com/jayarr-u17400.html
Mon Feb 08, 2021 3:30 pm
How bad is the rust?
The frames are built up for strength by nesting stamped sheet metal together instead of using thicker steel. The trouble I found was that once dirt and crud got in between the stampings it rotted everything out pretty badly.
I did my own car by replacing the frame rails with dimensional 3/16" steel but it was a lot of work.
Take a look at the attached pictures, everything with the grey paint was worked on or replaced.
Jeff
