it looks really good.aziankingz wrote:that is the cleanest underbody ive seen! youre really going all out on this project! good luck!
I am well aware of dealing with the extra weight. A 351 Windsor weighs 510lbs, about 140lbs heavier than a ka24de. LS1's weigh about 400lbs, so yes they are light compared to a ford v8.And yes, the windsor is different. The windsor has a deeper stroke than the cleveland and they have different heads. The cleveland has heavier heads but are mostly said to be more powerful. A cleveland block weighs around 525lbs. If anything I will go with a 302 instead of a 351, which weighs closer to 460lbs, not too bad over the ka's weight. Also, with the power than can be easily made from a ford v8 would help compensate for the weight.urcaptnspeaking wrote:Now you have to worry about weight issues if you care. The ls1 only weighs 575lbs fully assembled WITH transmission and thats why you see a lot of "hybrids" with that motor. ...Just so you know how many liters the motor has doesnt mean its bigger in size physically. Also, isnt the windsor different than the other 2 351's (modified,cleveland) ? Like theyre are bigger, or their heads are or something? I dont remember, im not a ford guy
agreed agreed and agreed. I've thought a lot about a 289 or 281 but it seems too easy, too common. I want to do something that I haven't seen before and holds an amazing amount of potential.I have a lot of respect for the ls motors since they are so light and powerful, that's hard to do. Thats really awesome you're putting it in a miata. I've seen some of those before. Once they get on it they get out quick! hahahaah.Yeah I hear you about people complaining about their motors too. A lot of my friends drive like idiots, one of them in a TC and he hits rev limiter AT LEAST 4 times a day for no reason at all. It's an 08' and he's gone through a transmission, a clutch, the transmission he has now isn't sounding too good, and his motor has a tap. I don't understand it maaan.urcaptnspeaking wrote:Get you a 4.6 then. Im not sure as to how much they are in comparison to the ls motors, but one from a cobra or something. Or even the 5.0 (which you said 302 already) something fuel injected.
^^No offense taken I have an ls1 sitting in my garage that I plan to put into a miata when I get around to it. I dont hate on anything unless I happen to know its junk. I like the ls motors becuase not only do they have great potential but they are one of the best motors gm has ever made. Stout enough for big power, light in comparison to things similar, and are very dependable.
Everyone has horror stories of "their motors" but I mean everything can and will break if you dont take care of it. And that goes to people who think 302's and such are junk. Most are now because idiots get ahold of them and cant keep out of the throttle and bouncing it off the redline, and then complain its junk becuase it didnt hold up to their abuse. Ignorence I say.
