89/91 transmission question
Gisshan
Can someone tell me if I can switch an automatic transmission in a 91 240sx with a manual transmission from a 89 240 sx.
Aries
Car: LT1 240SS
if you also switch the ECU and the necessary wires, then yes.
Aries
Car: LT1 240SS
Also you will need all of the other parts related to a standard transmission.
Use the search function (top right corner red button) and you'll find a lot more info.
Gisshan
I have a 89 240 with manual transmission and blown engine(think I threw a rod). I also have a 91 240(twin cam) with automatic transmission which has transmission problems. Will I be able to take the transmission, clutch, etc. from the 89 and put it in the 91?
