89-90 240sx mass air flow adapter
aznmystyk
do anyone know where i can get a mass air flow adapter with the holes to put in the air sensor??I tried to just put the sensor inside the cone filter but then my cars idle was going up and down, not stayin steady at all.
Aries
Car: LT1 240SS
Injen sells them with their intakes, maybe you could call them and get one?
quiksilvia
Car: 95 s14 se
ive seen them outside the intake, try that.
aznmystyk
quiksilvia:ive seen them outside the intake, try that. but doesnt the air have to flow through the sensor? Do you have an intake installed? if yes where did you put your sensor?
quiksilvia
Car: 95 s14 se
your maf is non-attached? or the little temp, i think, sensor with 2 small screws
aznmystyk
yea im talking about the sensor with the 2 small screws, i need a maf adapter with those holes so i can screw da sensor in it.
quiksilvia
Car: 95 s14 se
ive seen it just ziptied to something to hold in place, try that
aznmystyk
k ill try it thanks
RedShred
Car: 86 AE86
leaving my airtemp sensor loose caused lean conditions as it was getting warm from the underhood temps (I live in southern AZ kinda hot). I drilled out my intake tube and put it in there, zipped down the wires and taped it up to make sure it wouldnt leak.
