86 720 no power
hauntingurcoma
Car: 86 720
ive got a 86 720 z24 and it has no power at all.no headlights no nothing.no fuses are blown and batt is good. any ideas on what to check??also what is the firing order. which coil plugs in where?
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
alt?
breadbox
89 Koop
84 720 4x4KC
"The Z24 engine has 8 firing ports; four on the intake manifold side of the engine,four on the exhaust side. They are numbered one intake (i.e. I1)starting from the rear of the engine to four(i.e. I4) at the front.This repeats for the exhaust side as well (i.e E1 to E4 ). The appropriate ignition wire plugs are stamped on the distributor cap that is I1 will be inserted into I1 stamped on the cap."
zerothread/402513
hauntingurcoma
Car: 86 720
i dont think alt . the only thing that works is the little clock in the cluster but when i turn the key to on u hear a click from under the hood then all 12v power is gone clock stops,lights dont work ,nothing
