FritoVL »
https://forums.nicoclub.com/fritovl-u178266.html
Sat Mar 19, 2011 9:17 pm
I checked for vacuum leaks around the base of the carb with carb cleaner with no change in the idle quality. I even took the carb off and reinstalled it doubling the gaskets between the adapter and the manifold and between the carb and adapter with no change. I'm definitely hearing a valve rattle and not a ping. Although every now and then it sounds like a ping or more like a piece of metal bouncing around inside the motor but this sound is not consistent, and I didn't drop anything inside when I was installing the carb. There's only one vacuum line on the carb going from the advance port to the distrib. I've eliminated all the miles of vacuum lines and was running a Weber 34 (WeberCarbsdirect) before and never had these kind of problems. I changed to this carb because I was hoping to get better fuel economy. I'm wondering if I have a burnt valve or the valve seals are leaking. Would this create a vacuum leak or make the valves rattle when under load? As regards to fire: Its still the original distributor I've checked the advance by putting vacuum to it and I see that the advance works and holds the vacuum. The coils are also still original but seem to be functioning. I have E3 plugs on the intake side only, these are only about a month old, I pulled them a while back to check my burn and they were a whitish brown color, although when I pulled one a couple days back it was black in color but I figured this was from having to run it with the choke on to keep it running. Like I said before the idle is horrible but it only rattles when you put a load on the motor giving it gas. Any other suggestions or a way that I might be able to test the distributor to know if something internal is malfunctioning. One other thing I pulled the valve cover checked the timing chain and also checked the valve clearances. The chain is tight and I didn't see any slop, as I ran the motor with the valve cover off.
