86.5 VG30i
Discuss topics related to the VG and VE series engines.
halfyearD21
Car: 1986.5 Nissan D21 pickup w/VG30i
Does anyone have the tech specs, mainly check resistances and a vacuum diagram, for this motor. my book does not include this stuff, i can get it from NISSAN if i want to pay $85.00/hour and im sure they would jerk me around for a while and i really dont have the money. Or does anyone know where i can get a shop manual for this motor, its in the D21 pickup 4WD. Last but not least, performance parts, pistons, intakes carbs whatever i can get my hands on. Im looking to rebuild this motor and make it a beast.THANKS
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
Sorry for the delay replying to your thread.
I haven't seen any FSM's online for generation truck but you may keep an eye on eBay as stuff like that pops up every now and then.
As far as performance goes, the VG30 is an incredibly stout engine stock. As far as actually getting power out of it though... the only really easy and good way of doing it would be boost. They respond incredibly well to forced induction.
What kind of performance are you looking for? If you're wanting to keep it normally aspirated it will be very hard to make much more than stock. You would have to do some intensive work (higher compression, more displacement if possible, etc. etc.), which even then will get you minimal gains compared to boost.
What kind of power are you looking for?
halfyearD21
im not really down for adding a turbo as this would cost me way more than i have to spend, unless you know of a real cheap good turbo system and a computer system that will work with that. i really would like to keep it N/A because of where i am going to be using it. do you know of other cars the use the VG30i, more popular cars than my truck, which would allow me to find more parts for that car, import performance stuff. but thanks for your help youre the only person that has posted anything to try to help me, i have a couple other threads with lots of views just no posts! NO BODY LIKES MY CAR!!!!!!
mtcookson
1992 Iinfiniti Q45
and much much more
Oddly enough, it would actually cost a bit more to try squeezing power out NA than it would going with a turbo setup. As an idea, there was a fully build NA VG30E that made 300 hp and I think 240 lb. ft. of torque and the company wanted over $10k for it.
You could probably pay someone to make a turbo kit for the truck for half of that price and make more power as well. I've always wanted to turbo a Nissan truck but I've had a hard time finding a good deal on one that I'd like to modify (VG, 5-speed, 4x4).
Here's a guy that swapped in the VG30ET from a Z31. If you can do a swap like that with minimal fabrication (my guess, you would probably only need some exhaust work and maybe a custom motor mount). As this guy has done it, you can contact him and he should be able to provide you with tons of info and how much he spent doing the job. http://www.cardomain.com/ride/2358115
I actually don't know of any other vehicle that used the VG30i. Its kind of strange, I don't even know why Nissan used throttle body injection on the truck. The later trucks went back to the multi-port injection so it was kind of weird. I bet you could swap the ECU, sensors, intake manifold, and fuel system from a VG30E powered vehicle to have a better fuel system to tune with.
As far as getting the best out of it NA though, the only way to get big gains would be to bump the compression or get more displacement or both. Cams will make a good difference but won't add a ton of power.
There is one setup you could do, NA, that is one of the more powerful ones I know of (besides that super expensive 300 hp engine). You actually take a VG33E and put early Q45 pistons in it. You have to bore it out slightly, but you'll get a 3.4 liter VG that can make around 250 hp or so. That would be the cheapest way to make power NA.
halfyearD21
first i would like to say i would never think about paying 10K for a motor that only made 300hp, no offense. Second, the reason i dont want to turbo, is because as you said half that price of the NA motor is still 5000 and that is just a turbo kit, i still need pistons, and a whole rebuild kit to finish it off, that is just way too much mula. i know for a fact that i can build a NA motor for under, WAY under i might add, 5000, that will still make reasonable horsepower. Does anyone know if there is like a resident tech i can speak to, or atleast someone who makes performance nissan motors? i really do not have a problem adding displacement to a motor, i have a buddy who owns a Performance shop which has every thing i need to add displacement. i am really more interested in knowing the computers bounds, and how to tell if/which sensors are bad.
mtcookson
1992 Iinfiniti Q45
and much much more
I was just showing what kind of money it takes for them to make a high horsepower VG, I would never spend 10k on that thing... its just ridiculous.
I definitely mis-worded what I was trying to say. It would be even less than half. For instance, I turbocharged my Maxima for around $1,500 and could have even done it for less, but that using mostly salvage yard parts which still worked great. I rarely had any issues with the thing and it was a blast to drive... sadly rust killed it.
The beauty of the VG is you don't even really have to build up the internals for a turbo setup unless you're looking for tons of power. There are plenty in the 300-500 whp range on stock internals. They are very, very well built engines. If you're only looking for something up to the 300 hp range, a simple turbo setup would get you there fast and would be lots of fun. You definitely wouldn't regret it. A turbo I can think of off the top of my head that would be good is the T3/T04E 50 trim that you can pick up for around $600 new. That thing should support upwards of 400 hp and costs the same as a set of custom pistons would cost you for a slight overbore on an NA setup.
The downside to the VG and displacement is there isn't much room to bore out. I can't remember the limit off hand but I know for sure you wouldn't even be able to get it up to the 3.3 liters that the VG33 is. I know for sure it will cost you a lot of money to even get you close to 200 hp out of the thing. How much are you looking for though?
Most VG guys are going to tell you the same thing. I can't think of anyone that would recommend trying to build a VG up for NA power unless you have a VG33 and aren't looking for a whole lot of it. That's just one of the downsides of the VG, terrible NA performance potential.
As far as the computer, I would switch over to one of the later Z31 computers and injection system and use a romulator on it. I believe Nistune is probably the best one out right now for tuning the ECU's and that's one of the best routes to actually tune a car, is to use the stock ecu. They are quite powerful when modified, you almost have the same control as an expensive standalone unit (really the only difference is standalone units sometimes offer extra outputs for accessories like boost control or something).
As for checking sensors, you would need the info from a good repair book or the FSM to know for sure how to check it. One thing you could try is to cross reference the sensor part numbers on your truck to see if they are used on any of the other vehicles that have easily accessible information. For instance, we have the 84, 85, and 88 300ZX FSM here and if there are sensors shared between those Z's and your truck we can find out how to test them.
halfyearD21
ok i know you are really loving this turbo deal but let me put it in perspective the way i see it, and you can correct me if i am wrong. First i need to rebuild the motor anyway, even just as stock, because it is 21 years old and runs like a bad tractor. So thats a stock rebuild kit with pistons .020 over, i believe is 50mm which is a standard, lets say 500 dollars. Then your turbo at 600 dollars, then a programable modulator things to allow my stock computer to work with the turbo, another 600 dollars. May be more because of the application. now i need an intercooler, thats atleast another 200 dollars. Then im going to need all the ducting to route the air, buy the pretty stuff and thats in the 200 dollar range. i know its not much but all the oil lines, and adapters to allow for the turbos oiling. A custom turbo header for that car, thats another 400 dollars. cams to help it breathe right, another 300 dollars. it can go further i just dont want to, new high flow manifold, head work etc. Then even if all that is off by much, i still have to make it all fit in the truck. there is barely room for me to squish my hands in that truck let alone a turbo. the way i see it i will be spending every day for at least two months rounting and fabricating the mounting and piping of this turbo. when in two months i could a stroker kit for 500 dollars give or take, with pistons and rods, pistons atleast .020 over. put the cams in it for 300 dollars. do the head work(porting), valve job open up the valves to bigger size, this for me will be cheaper than the average joe as i know a person who does this stuff. and i should be able to run somewhat on the stock computer, since i did this with a chevy 350 to a 383 andthe stock computer did not seem to mind, and we pretty much doubled horsepower, and added plenty of torque. i know this is a completly different beast but the idea cannot be to far apart from them. so for the turbo thats 2800 dollars as of my numbers. and the N/A is lets say 1000 dollars with the porting and machine work, and i did not factor in porting and machine work for the turbo. so this is a big difference and i believe with a stroker kit, some head work and a few little trick things here and there i could easily pick up over 200 horses. unless im wrong please correct me. See i have to convince someone else that this truck needs a turbo, my dad, in order for it to happen as well. which is another story in its own. So if i made it to be more than it really is please let me know.
halfyearD21
sorry just wanted to point out inconsistancies in order to better understand what to do. in one post you tell me to take pistons from another motor and put them in mine which would make it be a 3.4 litre. but in your next thread you say i can only make a 3.3 litre out of this block. when talking about the 3.3 you mean just by boring out and leaving stock stroke. and when your talking about the 3.4 it is bored out and has a different stroke as well allowing it to be a 3.4 litre engine. is this correct
mtcookson
1992 Iinfiniti Q45
and much much more
There aren't any stroker kits for these engines to my knowledge and, if there were, they would be weeeellll over $500. To do a stroker means you would have to replace the crank itself with a custom made crank that has a longer stroke. Definitely not a $500 item... more like $2000+.
200 hp NA out of a VG30 will probably be pretty difficult to attain without very good cams, heavy port work, most importantly some custom high compression pistons, and probably more. You can't bump the displacement very much so that's not a route you can take with the VG30.
Valve wise there is a company that makes 1mm over sized valves for the VG30, which might help a bit in trying to get some power out of it NA.
The 3.3 liter I was talking about is the VG33E out of the:1996 - 2000 Nissan Pathfinder2000 - 2004 Nissan Frontier and Xterra1999 - 2002 Nissan Quest/Mercury Villager
It is a 3.3 liter version of your VG30. It has differences in the casting of the block to allow a larger bore for the 3.3 liters. With this engine you can get Q45 pistons and more out the block a tiny bit for a 3.4 liter VG33E. This is said to able to provide upwards of 250 hp and would be your absolute best route if you don't want to mess with a turbo setup.
I believe there may be some external differences on the block so there's a chance a you'll need custom motor mounts to get it in there. I've not seen much else info on the VG33 besides the Q45 piston setup. I know there are a few Z31 guys that have swapped the VG33 in place of the VG30 and put their turbo kit on, but I don't know what all was involved in doing that.
I think the biggest thing you'll need to do, regardless of what route you go, is to change out the ECU and fuel injection setup. I'd get one of the newer setups so that the ECU can be easily modified for better ignition and timing curves as well as a bump in the redline of the engine as that will help out with power production with proper mods (mostly cams as they can be designed for top end or low end power).
That should be good for now. I need to get out of here so I'll post more later if need be.
halfyearD21
ok you are right about the stroker kit, a friend informed me wrong, it was just for his truck i guess. what is the baseline horsepower and torque for this motor so i can really know how much i am going to be needing to break into the 200 range. if its up at like 150hp, 50 horses from a little bore, cams, porting, bigger valves, and a few little tricks here and there to knock down friction, and divert oiling away from the crank, does not really seem too out there. i have literally watched my boss pick up 50 horsepower just from tuning a N/A motor on the dyno, and by tune i mean jacking with the timing. so if i can find a carb manifold i would really be in good shape, since i will be able to really make it flow the fuel neccessary, since i dont really have any idea how to tune ECM's, and i dont really want to spend 600 dollars for a tuner unless i have to. Do you know of any carb manifolds for these trucks, or can i swap to an older one? Is this the first year they made this motor?
mtcookson
1992 Iinfiniti Q45
and much much more
I believe the VG30i was rated at 145 hp at around 4,800 rpm and ~167 lb. ft. torque @ around 2,800 rpm. Just as a comparison, later pickups with sequential fuel injection made 153 hp and the highest rating for a stock VG30E that I know of is 165 hp for the 87-89 300ZX. I believe a stock VG33E is rated at 180 hp.
As far as running a carb, I don't believe any VG's ever came stock with a carb. There was one company that did actually modify a VG30i intake manifold to accept a carb for Datsun 510's (VG swaps), but I'm not sure if they're still in business. Their website is still up so you may send them an email about it: http://www.vg30.com/510vg30parts.html
I'd look into changing around your ignition system as well if at all possible. I'm not sure what kind of options are out there as far as simplifying it (like going with a carb) but if you can, this will allow you to up your revs a bit, which will help with power output when you get the necessary breathing mods (like mentioned above).
Tuning is definitely a good idea, however you won't see a whole lot of power on the stock setup as they're generally pretty close to their limit.
Cams, valve springs (if upping redline), headers, carb (if manifold is still available) and you will see a decent gain. Custom, higher compression pistons and you might get around 200 hp or maybe a bit more. As a comparison, the VG30DE is at 222 bhp. It is a quad cam engine with a 10.5:1 compression ratio. Same bore and stroke as the VG30E so if you can make the SOHC head flow as good as the DOHC head and get up to a similar compression ratio, you theoretically should have around the same power. (cam timing, intake and exhaust manifold design will change the actual power output a bit as will the VTC's of the VG30DE, it won't be exact but may get you close)
Alternatively, If you want all of the info for the VG33 3.4 liter setup just let me know. I can find the exact info on how to set it up for the 250 hp setup they did.
halfyearD21
i dont really want to have to buy another doner motor, or a replacement motor. i would much rather just modify the good block i already have. is there any way a DOHC head from the VG30DE would fit my block, would this even benefit me if it did? what would i need in order to swap the fuel system to a later one? i know atleast would need a new manifold and the fuel system along with the computer and its sensors, but i would really like to stay away from installing wiring harnesses. are there any cranks that that will fit into my block, from other nissans, and have a slightly longer stroke?
halfyearD21
yea that carb manifold really looks like a turd! they just chopped off the seat for the TB and welded on a spacer. that is not at all what i was looking for. i want something real, not something i could build myself, i would probably lose horsepower switching to that thing.
mtcookson
1992 Iinfiniti Q45
and much much more
Actually, that manifold doesn't seem like too bad of an idea. The fuel is injected almost the same was as the throttle body injection so it probably does a pretty good job. I agree it could probably be built pretty easy though. Just an aluminum flange for the carb you want and have it welded on by someone good at aluminum. I wouldn't call it a turd though... you have to realize there is pretty much nothing made for these engines anymore... most of the stuff you want to do will be custom/do it yourself.
As far as other cranks, nothing that I know of.
The beauty of the VG30 is that there are so many available, you can generally get a good one cheaper than you can rebuild the engine you have.
The SOHC VG30 uses 13 bolts per head to clamp to the block while the DOHC VG uses only 8. On top of that major difference, oil and coolant passages will be different so it would be pretty much impossible to put a DOHC head on a SOHC block. Even if you were able to though, the amount of stuff you would need to add overall (intake, exhaust, computer for upgraded fuel system and VTC's) would make it an even worse swap than the VG33 as far as difficulty.
Wiring harnesses are actually very easy to pull out and swap. What's nice about Nissan's harnesses is they keep everything bundled, they're all one piece and only a few wires stray from the bundle for various external controls and feeds (power, ground, fuel pump, etc.)
The easiest way to find out if yours is like that is to look for a big bundle of wires coming out of the firewall. If there is one then that should be your wiring harness.
As far as sensors, you'd just have to compare what you already have to what is one the donor car. I've not been able to look at the stock setup that comes on your truck so I don't know what the differences are.
halfyearD21
not to rain on your parade there but maybe trucks are different from cars because i just helped a buddy track down a short in his 95 hardbody and after pulling the entire dash off it could be plainly seen that more than a few wires "strayed" from the main bundle. from the main bundle there were something like 3 other bundles on the inside of the truck. one going off to the left, to the right and some where else i cannot remember. if this is what you are referring to then ok fine. but it seems like quite a bit of trouble just from a view point. plus i would still need to find a computer wiring harness and fuel system, and sensors all from another truck. and as far as getting a VG cheaper than rebuilding it, i am not too sure on that. i found a rebuild kit for around 500 dollars. tell me who wants to sell a VG for under 500 dollars, mind you a good running motor, with computer and wiring harness( if it is not a VG30i). i dont want to buy another motor and put it in just to have to pull it and rebuild it 10,000 miles later. labor and machining will cost me little to nothing as i will be doing it all or mostly myself, i have access to a machine shop which is owned by a personal friend of mine, so if you are figuring that into the price of rebuilding, that immediatly flies out the window.
FoxFire
Car: 90 vg30eT 240SX, s12 vg30e
good luck with your AT MOST 200hp hardbody
if your homie really does own a shop just ask him to modify a stock 300zx turbo manifold to fit your truck and put the carb(with a bigger jet) before the turbo should take care of the fuel
go to any junkyard in the country almost gurenteed to have a vg30 block with low miles
machining a vg30 is not for most shops the clearances are VERY smallbut if you can find someone worthy, i would go with 8.5 to 1 compression pistons, rods , valve spring and a 3 angle job then 10psi boost with a stock t3
mtcookson
1992 Iinfiniti Q45
and much much more
halfyearD21 wrote:not to rain on your parade there but maybe trucks are different from cars because i just helped a buddy track down a short in his 95 hardbody and after pulling the entire dash off it could be plainly seen that more than a few wires "strayed" from the main bundle. from the main bundle there were something like 3 other bundles on the inside of the truck. one going off to the left, to the right and some where else i cannot remember. if this is what you are referring to then ok fine. but it seems like quite a bit of trouble just from a view point. plus i would still need to find a computer wiring harness and fuel system, and sensors all from another truck. and as far as getting a VG cheaper than rebuilding it, i am not too sure on that. i found a rebuild kit for around 500 dollars. tell me who wants to sell a VG for under 500 dollars, mind you a good running motor, with computer and wiring harness( if it is not a VG30i). i dont want to buy another motor and put it in just to have to pull it and rebuild it 10,000 miles later. labor and machining will cost me little to nothing as i will be doing it all or mostly myself, i have access to a machine shop which is owned by a personal friend of mine, so if you are figuring that into the price of rebuilding, that immediatly flies out the window.
The actual engine harness with be a single bundle of wires that goes from the ECU to the engine with very few actual wires straying from the bundle. Those other wires/bundles you saw were likely for the gauges, radio, climate control, etc. etc. There's a lot of wiring in cars but Nissan is very good about keeping the engine harness separate, especially on the later models like a 95.
As far as finding a VG cheaper than $500, I picked up 2 VG's for $250. One was a parts engine, the other still had the hone marks from the factory on the cylinder walls... it was in perfect shape. Only reason I pulled it apart was that it appeared to have metal head gaskets but turned out to be Felpro gaskets so I pulled those out for some regular head gaskets that Nissan uses from the factory. I ended up putting that engine into an 85 300ZX Turbo since it has the 9:1 compression ratio, which I feel would be much better for street driven car. I wouldn't bother with the lower compression turbo engines. The 9:1 setup will handle more than enough power and by the time you'd break anything you'd have to go with some custom pistons anyway. I love VG's.
Even if you get a VG30E, you can swap everything from your current engine to essentially turn it into a VG30i. VG's are easily 200,000+ mile engines when properly maintained. I know you could easily put over 300k miles on it if you felt like driving that much.
Since you do have access to machining equipment though, if you feel comfortable building up the engine I would most definitely say go for it! That would be awesome to have access to a machine shop, I'd be doing tons of stuff to my engines.
halfyearD21
yea essentially you just told me to make a BOMB!!!!!! yes you can put a carb infront of a turbo but it is about the stupidest thing you can do, even though gm did this on their firebirds. you do realize why this is a bomb right? plus i would basically be dumping fuel when ever i was not under boost, running rich as hell because the same air fuel ratio is not going to be the same. i talked to many other people and this was not something recomended. Plus what would be wrong with making 200 hp NA on a motor that has less than 200ci. that would be making at least 1 hp/ci. and as far as i am concerned when you build something that has that ratio (NA) you are doing very well for yourself. Especially if it is in a V6.
One thing i think everyone is not paying atttention to in my posts is that i am not trying to make a freaking drag machine, or anything super trick, or anything that is fast period. all i want is my TRUCK to have a little more bottom end grunt, im not going for mph or ET or even thinking of trying to run it that way at all. This is my DUNE climber, not racer, not baja 1000 truck, it is a FREAKING DAILY DRIVER THAT I NEED TO HAVE MORE BOTTOM END TORQUE. Essentially i need a stroker kit, as this is the best place to add torque.
mtcookson
1992 Iinfiniti Q45
and much much more
I never said to do a turbo setup with a carb. You somehow keep changing/misunderstanding things that I'm saying or something and you seem to be quite negative about any help I try giving you.
Power wise, the reason I asked you in the beginning about how much power you wanted was so that I could get an idea of what you're wanting to do. If you would have started with "slightly more power daily driver" I would have simply told you to do all of the bolt-ons available. With all of your talk about custom internals and such, I was under the impression you were looking for a pretty big increase in power because of the kind of work involved.
If you're only wanting slightly more power for a daily driving setup, here's what you need to do:
Cams - should be the single best upgrade you can make that is available for the VG (JWT makes pretty large cams or you can get some custom grinds from places like Isky cams)Fuel - since you want to go with a carb, that's already a given. Just be sure to have it tuned as well as you can to match your other modsHeaders/custom manifold/exhaust - small gain but will be good to do to match the cams. Don't go too large or you could make the low end power output decrease due to reduced flow
If you're going to be taking the engine apart you may consider doing some port matching to help overall flow, maybe a bit of polishing. I wouldn't try doing too much to the heads though as if you do a poor port job you can actually decrease the power output.
If you go with a cam company that does different grinds I would actually call them and tell them you want a cam setup for low end power, they should be able to do a custom grind that will benefit the low end of the power range a little more instead of a mild overall power increase.
That's about all you can do that comes to mind. You may consider a lightweight flywheel if its a 5-speed (not sure if one is made that will work with the truck or not though). Generally the lightened flywheels make it slightly more difficult to actually take off but should free up some power all throughout the rev range. If you need even more low end then you might just consider looking for a different rear differential setup, a higher ratio. This will give you much more torque to the wheels. It will hinder your highway driving if you do any as it will be at a higher RPM for any given speed. If you mostly drive in town this shouldn't be an issue.
That should be just about it. You are not going to find a stroker "kit" but if you want to spend the money can have one made... it will not be cheap, it will probably cost more than the truck is even worth to modify a crank... actually getting everything needed for a long stroke setup would probably cost more than nearly all of my cars combined. Not only would the crank have to be modified or one custom made you would also need custom rods and/or pistons... which in that case I would just spend the money to have custom high compression pistons made, which would increase power decently well. Custom pistons are relatively cheap as well, definitely much, much, much cheaper than a stroker setup would ever cost.
Not to sound like an *** or anything, but don't change around anything I say again. I'm trying to help you out and you're not letting me and attacking me. I asked for simple info on what you were looking to get out of the truck and once you started talking about doing a lot of internal work it made it sound like you were wanting a pretty big power increase. Now that I know that's not what you're looking for, the above should be exactly what you need to get exactly what you want so please, no more negative attacks against everything that I'm trying to say to help you out.
Good luck with it!
halfyearD21
no that comment was not intended towards you at all, it was towards the yahoo in front of your previous post. i am sorry if you feel attacked, i may be a bit defensive because it seems like everyone is just yelling out the most insane mod for me to do. i am not doing this for bells and whistles, or so i can say i have some bad *** truck, i just personally would like a little more power.
i was considering a lower gear set, but unfortunetly i would have to do this in the front as well, since it is a 4WD. but if i could pick it up cheap enough that wouldnt be too bad. but if i do that i am going to want to atleast put a new LSD in the rear because i think the clutches are gone in it, if that is even how this system works.
assuming i keep the fuel injection what kind of air flow will be acceptable to the computer/mass air flow sensor? do you know of any bigger valves for these heads as well?
mtcookson
1992 Iinfiniti Q45
and much much more
Man, I am very sorry about that. I didn't notice that another post above, completely my fault. If I ever blow up like that again without merit just let me know and I'll kick my own *** for you.
The 4WD will definitely make it a bit more difficult to pull off. I bet they do probably use a regular "R200" style setup up front so you could possibly change the ring and pinion out for a higher ratio but that may not be something you'd want to mess with. I don't know if anyone has done it before so I wouldn't know of all of the work involved in doing that. LSD wise, I bet actually it probably just has an open differential actually. Being 86.5 though I'm pretty confident it will be open as the 300ZX didn't even get LSD until 87. Just to be for sure, one of the easiest ways to check would be to look at the differential cover itself (if it has one, not sure how they did the axles on those trucks). Generally LSD diff. covers will have fins on them for extra cooling while open diff. covers will be smooth. Another way to check is to lift the rear and spin one tire. The other will spin in the same direction with LSD and the opposite direction without.
Air flow wise it should handle the bump in power you're looking for without any issues. The only problem you'll have with that system is when you start reaching the limits of the stock system, which generally would take quite a bit of power (more than can likely be attained with general bolts ons and such).
For bigger valves, Ferrea makes 1mm over sized valves. Those are the only ones I've ever seen and are said to be at the limit of what the stock head can handle size wise. Jury is still out on how much they help out, not much data yet that I've seen.
Kind of a strange coincidence, in this thread zerothread/308149 the guy is in this race series that actually uses the VG30 with the TBI manifold but with a carb on it. They actually just use some sort of carb adapter to switch from TBI to carb so that may be a pretty decent option for you if you're still thinking about that. You might get in contact with the guy to see where they get the adapters from. I looked over the race series' site to see if they mentioned but couldn't find it so he may know.
halfyearD21
ok do you personally think i should go with carb or keep the TBI. i do not want to have to do Multi port fuel injection. If i stay with the TBI what am i looking at for computer control? Who has something to aid in my fuel situation, (ie romulators, ecu controlers)?
As far as the LSD goes i am pretty sure it had one to begin with because i could always spin both tires, peeling out or in the sand. then after a little while of driving it i noticed it would only spin one, in sand or peeling. so i decided to drain the fluid, and to my surprise A LOT of metal came out. Other than one tire not spinning, the Diff works great, not crunch, grind, or anything. So i was just assuming that the clutches had worn out and that was the metal in the bottom. So even if the clutches are worn and i spin one tire should the other spin in the same manner, or should it act as an open diff.
mtcookson
1992 Iinfiniti Q45
and much much more
That's definitely a tough choice, between carb and TBI. The TBI should be a little more efficient overall and, as far as bolt-ons, I think will handle modifications. The carb would be a little easier to tune for higher power as far as not having to screw with electronics.
If your truck has the older style ECU then it'll probably be a bit harder to modify compared to the later ECU's... being TBI though they may not use the "later" ECU's at all, I'm not sure there. If the ECU has an EPROM in it then you should be able to tune it using a Romulator or similar. If not, then the carb would definitely be the easier route as you'd have to swap fuel injection systems.
Another potential option could be a piggy back fuel controller, something like the Apex'i S-AFC. The only issue I can see there is whether the MAF would be supported or not. If you could make it work though that would give you enough control for fine tuning the a/f ratio.
That would definitely be interesting if it had an LSD in it. I know I've sometimes got both tires spinning with an open diff. and other times one wheeling it. Anyway... if it does happen to be a clutch LSD then I believe those can be rebuilt and are definitely the preferred LSD to have. The other is a viscous LSD, which can't technically be rebuilt and just has to be replaced (the viscous unit). That's as far as I know differential wise. I haven't got to mess with those much yet.
eds13
Car: 89 240sx Hatch, 07 Armada LE, 91 Skyline GTR
so no one found any vacume diagrams then???
i just picked up one of these, and it runs like garbage, even after the tune up i just put on it. no power in higher RPM range, and bogs terribley when you go foot to floor.
Zdaddy
Car: '86 Nissan 300ZX
Just to set the record straight....yes there was a carb VG it was called the VG30S. There is a picture of it on my site somewhere.
And yes they make stroker kits for the VG30E, look into Paeco, otherwise it is correct that it will cost more than $500 for this kit. You can also adapt the DOHC stroker kit from JUN but thats an even more ridiculous price.
mtcookson
1992 Iinfiniti Q45
and much much more
Ehhhh... I've not heard of many good stories from Paeco, I can't believe they're even still around.
If displacement is what you want/need... I'd just go VG33.
FoxFire
who's the yahoo?your the one trying to modify a 130hp carbed vg
the only way you see more then 200 hp, is if you turbo it, other wise the $ per hp with be RIDICULOUS
anything less then 200hp will not work in the sand with the stock gearing
maybe a low gear ratio differential would help you with rock crawling and might help you in the sand so you don't bog down
Zdaddy
^^ I agree 100% with FoxFire. Nissan's TBI and Carbed VG's are for low HP apps, whilst maintaining torque (IE Trucks and SUV's) If your gonna take it out and "make it a beast" your gonna need Boost, and with boost you need fuel and I dont think your gonna make much head room in the R&D Carb department in that sense.
If you wanna stay TBI, maybe is an option...with other appropriate upgrades of course...cause you still need fuel to not go lean with all that NOS. Lean=bad.
MTCookson, whats wrong with Paeco? I haven't heard anything about them. Email me [email protected]
mtcookson
1992 Iinfiniti Q45
and much much more
Somewhere I heard a bunch of bad stories about them. I'll have to search for it again.
halfyearD21
First off do not tell me that anything under 200hp will not work in the sand because with this stock truck running like a turd i already climb more/bigger dunes than guys with 454 in their chevy trucks. Secondly you have a pic of a car not a truck a car. leave the off roading to me, not you. Plus with a cam from JWT, over 20% gain in hp, hedders, around 10-15% gain in hp, little higher compression pistons, some head work, valve job, and doing all the little things that add up i should be around if not over 200hp. Im not looking mainly for hp anyways. When i say beast, i mean beast of torque. You truly think that a cam, hedders, a distributor, carb, and mostly free machine work will cost more than a turbo, an intercooler, all the ducting, the new computer, then add on all the time to make all the extra stuff fit into the already cramped D21 engine bay, you are out of your mind. AND FOR THE LAST TIME I DO NOT CARE IF IT IS OVER 200 HP! THAT WAS A GOOD ROUND REASONABLE NUMBER TO SHOOT FOR! NEVER SAID I WANTED ANYTHING MORE! And NO ZDADDY i am not going to put my truck on the bottle because bottles are for babies. if youre really into making power you will man up and make it not through gas at it till it blows up. And yes lean=bad. So even if i put gas on it, there would still be high cost for nitrous pistons, and a new comp program, or comp altogether.
Return to “VG30 / VE30 Forum”
