DoctorRobert »
https://forums.nicoclub.com/doctorrobert-u121453.html
Mon Apr 19, 2010 5:21 pm
Ok guys, here are some issues I've been having with my 300zx I'd love some help with. I have done a look of searching, but haven't found any direct answers yet.
The car - 1986 Nissan 300zx 2+2, non-turbo, automatic. Digital climate and dash.
Climate control - very common I know. It blows hot. I went through a fixed the vacuum lines (supposedly) and it doesn't just blow out the defrost vent anymore, but it still blows hot. Here's the odd thing though - sometimes it will blow cold, then (most) other times it blows hot air. Being in this 90 degree weather, it's really killing me. And when you get up to about 30 MPH - even with the fan off there is still a nice amound of hot air seeping from the vents, and on the passenger side floor board there is a steady blast of warm air (as if the fan were on). Like I've said, I went through the vacuum lines and, unless I missed one, they should be good now.
While right now I am more interested in fixing the heating issue, it has another small problem - after sitting for about 40 minutes it is a little hard to start. Runs perfect afterwards, but when you get in it to start it, no matter what the temperature is outside, you have to pump the gas and feather the gas for a few seconds before it "catches" and starts idling around 5 - 600 RPMs, until eventually building up to around 800. I figure with that one maybe the CHTS? It does not appear it was changed during the engine work.
Thanks! Any help is very appreciated.
