85 N/A Coolant Question
A home for 1983–1989 300ZX owners!
xX RB Xx
Car: SE3P, FC3S, FC3C.
Ok. are there any other Coolant sensors? I was trying to say that say my resivor isn't hooked up to my overflow system. My light just came on two days ago but I have had coolant leaking for the past week.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
what light is on? the little birdcage thing comes on when the cooland level is low or empty ont he resivior, thats the only sensor that makes that light come on
you have a temp sensor ont he intake manifold that goes to the gauge on your dash, it makes the gauge wotrk and thats all that it does
there si a CHTS on the frotn of the drivers side engine head, near the thremostat, it sends the temtp to the ecu which effects fuel mapping, and thats all that it does
this clean anythgin up for you?
xX RB Xx
Yeah that clears everything up. I was just wondering if there were anymore causes for the coolant warning light would come on besides the resivor being low.
evildky
06 Nissan 350Z GT
nope
kasilvia
Car: 97 240sx
That is part of the cooling problem. The cap allows coolant to travel to the resevoir. If you hook it back up, it wont puke out of the overflow hose. Anytime it gets warm and you shut it off, it will bleed the pressure that builds up as the coolant is no longer circulating or being cooled by the fan. Try reconnecting the resevoir, replacing the cap, and then check for leaks again.
xX RB Xx
Ok I'm going to do that. I really haven't had the chance to mess with it in the past few days. I went and bought coolant last night after I got off work.
xX RB Xx
Do you think when I had my system pressurized that the coolant might of been coming out of the release nipple thing. Omg I'm having a brain fart and can't remember what the name is
xX RB Xx
I got my overflow line fixed and filled up the take along with a new radiator cap I didn't have a chance to drive it around but I did run it for a few and didn't notice any leaks .
ZSpecs
Car: 1992 Z32 2+2
Don't forget to burp the system.
xX RB Xx
Burp the system? I've never heard of that phrase before.
Anyways I tool it out today and it still leaks but it's a drip when the car runs and right after you turn off the car. I think it's that hose that is in the picture above
Perrenial Badass
Car: 1973 240Z, 1986 300ZX, 1987 300ZX, 1984 Corvette
Burping refers to getting any air out of the system.
xX RB Xx
I knew what he meant but i've never heard of that phase before.
evildky
06 Nissan 350Z GT
the Z31 filler neck is at the highest point, bumping isn't generally needed, just be sure the heater is on when you fill the system
Z32's are a HUGE pita to burp
xX RB Xx
ive got a question.. i fed up with this coolant leak, so im going to replace everything that is associated with the coolant system (except the radiator)
my question is.. when i replace the timing belt should i go ahead and replace the timing belt tensioner? it was replaced under 3k miles ago when the car had its last maintenance, with its previous owner.
Perrenial Badass
I would, but you don't need to.
xX RB Xx
I would like to, but I'm limited on my funds for this month and I cant wait until next moth to fix my problem.
evildky
06 Nissan 350Z GT
if the tensioner is only 3ms old I'd keep it, was the tensioner stud replaced as well?
xX RB Xx
Honestly... I have no clue. I can only assume it wasn't replaced.
NissanFairladyZ32
Car: 91, Twin Turbo, 99 Miata 1.8L
If the stud hadent been replaced or if your in doubt get a new stud from nissan, they are cheap
id just put a new waterpump on there $40 bucks and replace the coolant lines you think are bad, and thermostat while your down there
Return to “300ZX (Z31) Forum”
