84 720 2wd - super noisey and vibrates over 40 mph.
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
mikepolk
Car: 1984 Nissan 720 2WD Standard Transmission
This just started about a week ago. Over 40 mph it get really noisey and vibrates really bad. If I let off of the accelerator, the vibration and noise stops. What is this?
drumaniac3000
Car: 1986 720 4x4
u-joints possibly?
lambohaha
Car: `85 720 2wd std cab
Belts separating on your tires? Wheel weight fall off?
MetalFab
Car: 1985 720 4x4 reg cab flatbed.
U-joints can lead to some really interesting sounds, and is the first thing to look for if you have vibration. Get under the truck and try to rotate the driveline back and forth. it's easier if the rear tires are off the ground but if there is any play at all then you've found the culprit. Also the majority of drivelines have some kind of weight welded onto them, it's rare that they come off but it would be good to inspect and see that there is a weight on it, and that there aren't any weld spots with something missing.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Id say driveshaft.
captainzeros
Car:
1981 Datsun 720 Longbed
1973 Datsun 240Z
on my 2wd there is a rubber bushing around the driveshaft. It rotted out and then the driveshaft started shaking around which made a real scary noise at speed. Crawl under you truck and see if you can move the driveshaft left/right/up/down to check on that.
lambohaha
What about the carrier bearing? Maybe its going south :rolleyes:
lambohaha
Well? Any new developments?
86 720
Car: 1986 720 4cyl Standard Cab
wheel bearing, or steering pump?
Return to “Datsun 720”
