'77 620 Idle Drops/Electrical Gremlins
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
rdurost
Runs smooth, idles like glass at 700 or so, then blaahhh... Like flipping a switch it suddenly drops and tries to idle at 200. Fuel and spark are fine--it doesn't stall like it was shut off, the idle speed just drops like a rock. Give it a little pedal and it idles fine. It seems like some emissions equipment is mis-adjusted. BCDD? Something else I never heard of?
It initially always idled too fast, like a vacuum leak, even with the idle screw backed all the way out. Is some valve open to outside air most of the time, then closes??
Also, erratic instrument panel operation. Gauges/turn signals sometimes work, sometimes not. Anybody know where the panel ground wire is?
J.E.T.
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
Hello...Welcome!
Did you replace your EGR? Also..you may want to check your bolts/nuts around the intake and carb if you have had it off.
If you have an electric choke then check for power. I don't like emission crap on those carbs...check your wires/connections. You can find a wiring diagram here: http://www.olddatsuns.com
Return to “Datsun 620”
