74 620 series
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
74dat620
Car: 1974 Dastsun 620 Series Pickup
hey there my name is Abel, and i currently have a 1974 620 and up until about 3 weeks ago it was running. The hose running from the head to the carb collapsed, causing back pressue and shot oil into the carb. I replaced the hose and the truck ran fine for about 2 weeks then it started losing compression again like when the hose had collasped. It will turn on and run but once it warms up it starts to lose compression and it is smoking an awful lot, white smoke. any ideas?
thanks
PEZi
sounds like a headgasket
that would explain the loss of compression as well as white smoke
74dat620
thats what i thought it might be
is that a fairly simple repair? cause i like to think of myself as a 'backyard mechanic'. or would i have to have someone else do that for me?
PEZi
click here and see if that helps... it is easy enough if you have the stuff to do it
74dat620
thanks..that doesnt seem too hard..going to see if i can get started on this weekend and have my truck back on the road next week
Return to “Datsun 620”
