73 620 - Dash oil light stays on
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
spanner
Car: 1973 Datsun 620 pickup
So switched off immediately. Question: Could there be a reason
other than a failed oil pump ? Oil level is fine. Oil and filter was
changed relatively recently.
Truck was running fine before this.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Sure, a failed sensor switch. Put a mechanical gauge on it, if the pressure is normal then the problem is in the switch, wiring, or cluster. You can vindicate the wiring and cluster by yanking the wire and then grounding the wire. Removing it should extinguish the light, grounding it should make the light turn on. If so, the circuit and cluster are good.
spanner
Thanks for the tips. Seems easier to just replace the sensor.
We'll see how it goes from there.
Return to “Datsun 620”
