evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Jul 08, 2009 7:24 am
first I'd get a propper gauge, and make sure it's hooked to a good port ont he manifold, then look for any cracked or broker vac lines, then takk a good hard look at the idle air hoses, check the coupler form the turbo to the J pipe, and make sure the J pipe gasket to the TB is good and nto cracked,might be a good idea to go ahead and change the PCV valve, and have a good look at the your itnake manifold gasket
