Charlie69 »
https://forums.nicoclub.com/charlie69-u119658.html
Thu Apr 16, 2020 3:26 am
Start by wrapping steel fuel line with rubber fuel that runs along bottom of valve cover on carb side of the intake manifold.
Are you running the stock Hitachi Carb?
Are your intake and exhaust manifolds bolted (married) together? If they are there is a heatshield that should be between the carb and intake manifold. You can easily make a heat shield by tracing an carb base gasket.
