620 dually?
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
robfixhondas
Car: 1978 720
So im about to remove the bed off my 78 620 (which by the way is held together by ratchet straps) to build a flatbed, but before i do i want to make it a dually. now im not necessarily looking to do this to increase the load capacity, more so doing it for looks (id say about a 50/50 split) but im having trouble finding any wheels or even adapters to do this. im wondering if anybody has done this kind of thing before and how it was done so i can get some ideas.
PEZi
i'm pretty sure pulling the rear axle off of one the trucks that is already a dually might work out... some 720's had them, i believe a few 620's had them too... toyotas had them as well
never seen anyone do an actual transition before... but i'm sure there is someone out there who has
multipro66
Car: 90rx7
There were a few 620's made in 77 and 78. Check out the NWDE website, I believe there's a guy on there named Bleach, he's a pretty sharp fellow and some hwo manages to find pics of off the wall stuff like the duallytruck and my favorite the 620 California Sunshine mini which is a model of a widebody shrtbed truck which was raced in Baha like events.
makya
I had a 620 dually. the rear end is the same, they just had a severe offset single deepdish rim with two sets of tire beards on it. Some of the RV's ad real dually wheels, but I aven't seen any around.
this is us spec only, the south american models had a true dually rear iirc.
1200Racer
Car: 1995 Nissan 240SX, 1986 Nissan 200SX, 1979 Datsun Pickup
I still have my 79 620 dually. As noted in a previous post, they came with some funky dual wheels. I used mine to tow my 1200 SCCA race car. I went to a dual wheel set that was made by Appliance Wheels. They were called Double Truckers. I don't think the company is around any more. The axle was stock but running the duals caused the rear wheel bearings to go out faster than normal. I think I replaced mine a couple of times.
Once I quit towing with it, the maintenance got easier. I put Recaro seats in it. The rear cab section has a full bench seat with sliding side and rear windows. Unfortunately, the engine went south when a valve dropped. I found an L-series block that turned out to be bad so it has sat ever since. Fortunately, it is stored indoors. I would like to get it running again if I could come up with a decent L-20 engine or block or even better, do a swap to a more modern engine
PEZi
^ welcome!
don't forget to stop by the datsun cars forum... and we love pics of cars! especially those of SCCA type ;)
ProRiver386
hey , i think i got everything you need to set your truck up as a oually! i have two differnt set ups. [1] i have the back rims that are about 16in. deep ,that have ,how can i say it! that have an inner bead welded in [2] ,so it will accept two tires! looks cool THEN i have a real set [6] rims . the inside rear set ,bolts on normal to the drum, and has a flange welded on the front of it,that has wheel studs [5 lug pattern [big] ] then the outside rim bolts to that! ! Looks good too! And for the front, i have wheel adapters [spacers] that bolt to the front drum, that has a flange on the outside, that has wheel studs [5 lug pattern [big] that a rear rim, turned around, bolted on! Make it a REAL dually set up! ALL these rims are 14 in. Silver in color, and ALL for sale!
1200Racer
the two piece rear set seems like the ones I have that were made by Appliance Wheels; much better than the OEM one-piece setup; the front; mine are painted white
CrawfordZ
i have a white spoke dually kit for a 620 datsun-14''
itsa260not240z
Car: 1974 datsun 620 1974 datsun 260z 1978 datsun 620
I have seen a four door 620...
1200Racer
there were some made in Mexico that were 4 doors; I saw one a long time ago
Bilboy620
Car: 620 Datsun
Bilboy620 I have a 1979 620 with the four rim 6 on 5.5 dually wheels, love it! I am looking for another set of 14" wheels to put snow tires on. I would prefer the four separate wheels for ease of tire changing, but I could use the type with 2 tires on 1 rim. If anyone has a set of wheels that they would part with please let me know. Thanks
Return to “Datsun 620”
