seang »
https://forums.nicoclub.com/seang-u122444.html
Mon Apr 20, 2009 5:27 pm
Also, the throwout bearing could be only halfway siezed due to excessive wear and tear, (bearings don't just collapse). many times with these trucks, the case is that the clutch components will go out before the clutch disc friction surface wears completely, so it will not nessesarily slip, but the other components still fail, especially on a 22 year old rig. But before you spend lots of money on a new clutch, make sure you have the correct amount , (and type), of lubricant in the transmission. Its all about saving money, right?
