4x4 help
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
marmstrong35960
Car: 85 720 4x4 32/12.50/15
Lightbar. Net tailgate
Brush guard. step tubes
85 720 4x4 hubs feel like they lock when I turn them can grab front drive shaft and try to turn the rear moves and the Cv shafts move this was with all 4 Tires on the ground any help would be appreciated need to fix quickly on way to get off this mountain if it snows
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Sounds like the hubs are not engaging at all if you can still spin the shafts.
marmstrong35960
Tore my hubs apart found out some moron forgot which side of the inside gear the snap ring went on I hate idiots that think they ate mechanics
marmstrong35960
Put everything back still no pull internal parts move but believe the spring is bad gonna figure a way to make them work till I get the money for a set of warn hubs thinking a couple of snap rings between the outer hub gear and the spring should work only needs a little more travel
Rev_D21
Warn hubs are nice but why not borrow a set off a junk Nissan at the junk yard?
marmstrong35960
None of my local junk yards have any 720's or Nissan 4x4 with. The right hubs I am thinking about going fulltl time 4x4 anyway
Rev_D21
Well as they say, something breaking is only an excuse to do some upgrading.
marmstrong35960
Yeah me and a friend designed an easy way to switch manual hubs to full time we are gonna make a kit to fit my 720 we are thinking about patenting it and selling a few it works good on his 95 7.3 bronco we built :confused:
marmstrong35960
Put in 2 snap rings and got my hubs working till I can get a new set or I might do a sas this spring
Return to “Datsun 720”
