[4th gen} Alternator Replacement Question
OwnerCS
Tonight I started to replace the I30's alternator. I quickly realized that I may need to drop the A/C compressor to reach the bolt behind the alternator.
When changing the alternator, do you typically remove or drop the following items?
1) Remove the lower radiator hose?
2) Drop the A/C compressor?
3) Discharge the A/C system to remove a line so the compressor can be dropped far enough to reach the bolt behind the alternator?
Any tips will be greatly appreciated.
A33 Cefiro
Car: 2001 Infiniti I30
I have done this on my A33. IIRC both engines are the same, so what I did was remove the lower radiator hose. I did not touch anything A/C related. It's easier to remove the hose and the whole radiator if you have to.
Good luck with it.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
You shouldnt have to discharge your AC -just loosen up the mounting bolt
This is what the FSM says
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
It's been a while since I replaced the alternator in the 99 I30 but I don't recall touching anything AC-related...just the idler pulley and radiator hose.
OwnerCS
All went well with the replacement job. I finished it up late Friday night. I replaced the idler pulley tensioner assembly and the belt.. The old idler tensioner had broken so it had to be replaced. I replaced the idler pulley as preventative maintenance.
I took a slightly different approach for replacement. I was able to replace the alternator without removing the radiator hose or disturbing the cooling system.
I removed the A/C compressor bolts and lowered the compressor enough to reach the inner alternator mounting bolt.
Really it wasn't a bad job..
