AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Sat Mar 08, 2003 6:36 am
Not a cop, correct.
Driftaholic is right. You DO NOT want to use an aftermarket harness as your daily "protection". They are far more restrictive that a standard seat belt, for one. Also, they are designed to save your life, NOT prevent injury. Standard seat belts are designed to do both. They allow deceleration of your body weight in the event of a collision and still allow full mobility and range of motion.
I am pretty certain that a properly-installed (yours is likely NOT) is perfectly legal. Howevr, removal of the factory belts IS NOT , so you're in a Catch-22.
Even loosening the bolts that hold in the stock belts is a bad idea - Thy are "loctite-d" from the factory on purpose.
For racing, you're almost better off just strapping your a$$ into the seat with a couple regular tie-downs (if you must). But wear your seat belt as well.
