tyrodtom »
https://forums.nicoclub.com/tyrodtom-u133407.html
Sat Mar 19, 2011 10:21 am
You've got a lot of small electric motors in a 240, for the headlight doors, power windows, power seatbelts, fuel pump, power antenna . Then power door locks, and so on. If any of the relays or switches are stuck in a on position it wouldn't take long to drain a battery.
Get the car in a quite area, with the key out, listen for a hum, it won't be very loud. This isn't likely, because none of those motors can run against full resistance very long and not blow a fuse.
You need to get someone with a mutimeter to go thru your fuses and see which are still passing current when the key is out.
