30k maintenance --- ideas/suggestions/what do you do
hsckris
Car: 07 V8 4runner
My Frontier just hit 30k --- Nissan recommends coolant flush, diff, transfer case, & trans fluid change, as well as fuel filter, in cab. filter, rad. cap, drive belts.
I normally do fuel filter & in cabin filter. My dealer also changes spark plugs at 30k (wtf -- I think they are 100k rated). I don't think there is any need for rad. cap & drive belts.
I guess I'm asking do ya'll have any thoughts? On my previous/other vehicles I've always done trans/colant/diff/trans case & plugs at 50k, belts & rad. cap as necessary.
I do drive offroad a half decent amount, and I'm not the easiest (or the hardest) on vehicles, so I like to keep up with maintenance. I just wanted to know if ya'll thought 30k was a bit too early or what....
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
30k is a big service for your truck but I suspect that a lot of those items are inspect only.
hsckris
Car: 07 V8 4runner
Nope -- Nissan calls for changes as referenced above. I normally do all my own service when possible, but I just thought 30k was a bit premature to be changing trans case, diff, transmission fluid, & coolant.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Trans and coolant flushes would be at the top of my list. Belts are probably OK, but inspect them closely for cracks, and as a precaution, carry a set of spares and the tools to swap them when on the trails.
hsckris
Car: 07 V8 4runner
Welp, I'm gonna go ahead and do it.
I'm glad we have the FSM hosted -- makes things a lot easier. Thanks AZ!
Ya'll think I need to flush the coolant or just R&R? In the manual it says "Replace engine coolant/flush system" -- ambiguous at best.I may end up having a shop do this for disposal reasons (though I have a safe/proper avenue).
What do ya'll use to lubricate hinges/latches/locks? Lithium grease?
Thanks for your help
Any recommendations on gear oil?
hsckris
Car: 07 V8 4runner
hsckris wrote:I'm glad we have the FSM hosted -- makes things a lot easier. Thanks AZ!
+1 again on that.
I did it --- awhile back now actually, just thought I'd update.
It wasn't that bad, getting the gear oil in to the front diff was a bit tricky b/c the bottle wouldn't physically fit in the space available, so I just used a piece of tubing (which took forever).
Everything else went pretty smooth. Trans fluid came out clean, so I only ended up replacing ~5 qts... I figured it'd be good to go.
Forgot to do the in-cab filter so I'll do it when I do my wife's brakes here shortly.
sdcaller
Car: 2004 Titan LE
Newer diffs, esp. on Titans, are pretty tight - would recommend diff fluid change now.
Add one more: clean your maf sensor, esp. if you have a wet filter (K/N, etc)
BWSan Diego
