nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Sat Aug 22, 2015 5:29 pm
Is your car a 2+2 or 2+0? Auto or manual? All these makes a diference. Did you get the one for the TT or NA? The TT rear end has a CV jointg and 6 or 8 bolts that connect to the rear end. The NA only has 4 and a ujoint. If you swap a TT into a na, you need an NA driveshaft, not a TT shaft.
The 5 speeds are the same, well minus a few things, but outside they are same dimension
Auto's are different in the TT and NA, and are longer
If you got it from Z1, let them know. It is possible they sent you one that is a little too long, it happens. The get the shafts from an outside source. It very well could be their mess up.
The only other issues if your car was in an accident, which coud have pushed the engine forward, but you would have other issues with other things not lining up. To answer your questions, no worn mounts will not cause it to move back 1/4 inch. Down 1/4", that is very possible.
