300ZX N/A to RB26DET
A home for 1983–1989 300ZX owners!
4AM
Car: '86 Nissan 300ZX, 2 seater, T-Tops(VG30E)
After looking at possible build ups on my VG30, I've pretty much set my mind on the Skyline RB26DET. The engines I've been considering are not new. i am in high hopes this will satisfy my HP need and allow me to have a more personalized 'Z'. i will try to post each mod as it comes up after the engine and transmission arrive. There should be plenty to remark on this swap!
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
Have you even priced out an RB26DETT and transmission yet?
raremotive
Car: 04 Infiniti G35
rb25 better option to go, it will get just as powerful as a rb26... before extensive mods are needed.
sek8031
Car: 1980 280zx
HP Need? Is that like some kind of diabetes of the right foot?
mikeith
Car: 73 240z
Rare_f8 wrote:rb25 better option to go, it will get just as powerful as a rb26... before extensive mods are needed.
the bottom end on the 26 will handle more and the head flows better. you'll need a rb25 transmission though.
its a pretty costly build eitherway. you'll spend just as much or more on everything you have to do to make it work as you will on the engine transmission alone... realistically looks 7-8K+ if you can find an engine/transmission for 3500 or so
raremotive
By not very much, rb25 can take a betting and suffer the same weaknesses. Weak piston ring lands. And once pushed to the limit both begin to lose a rod bolt. But, 400 to 500 hp rb25 are very common.
Compare stock verse stock the only thing the bottom ends have different is a beefier rod on the rb26. But, they still suffer rod failure just like rb25s. When you look at it, both have the same 2 bolt cross areas being stressed. Never seen a ROD failure on either motors or any. But I have seen many rod BOLT failures.
in order weakness is:pistons>rods bolts>valves
rb25 will get you to your goals much cheaper, they are practically the same motor. Cept the rb26 has the hysteria behind it.
^ I will agree. It's a costly build. And I can pick many motors that will weigh less and give more hp for a lot less.
mikeith
Car: 73 240z
unless you are wanting to make more than 400rwhp, than it would be much cheaper to build a killer L28ET
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
he has a Z31, building the VG30ET to well north of 400 whp is WAY cheaper than the RB swap
sek8031
Car: 1980 280zx
But...but...It's just not as coooooooooooool!!
Nobody wants to admit that they don't drive a Skyline.
raremotive
even if you put a rb in it you still not driving a hyped up Skyline.
AZ-ZBum
Rare_f8 wrote:even if you put a rb in it you still not driving a hyped up Skyline.
No. He'd be driving a Z31 with a motor that's worth more than the car.
evildky
06 Nissan 350Z GT
AZ-ZBum wrote:No. He'd be driving a Z31 with a motor that's worth more than the car.
thats true of most Z31's
raremotive
evildky wrote:thats true of most Z31's
4AM
Yep, I've priced about 50 of them. And I've found myself fine with it, unless I come across an S30 (which I'll still build up the engine or replace it) I'm going with a more race proven engine...and I still want a 6cyl.
4AM
Its a form of frustration, from the car not preforming when I need (want) it to.
4AM
Yeah, i'm ordering the RB25 transmission seperate... actually first. I wasn't aware of the transmission option till I started shopping for an engine.
4AM
I considered this, but it seems like I'm going backwards...
4AM
My VG30 has so many miles on it, previous owner never keep up with maintenance. Its just worn out... and the transmission has about month, if I'm lucky. I really don't have a choice, if I'm going to replace the engine and trans., I'm going better.
4AM
I'd like to also add, i don't care how much money I spend on this build, I'm not rich, but I'm willing to save and buy what I need as I can... if I had all the cash on hand. I'd have an 10th Anniversary FairLady Z shipped over, but that's just not the case.
evildky
06 Nissan 350Z GT
4AM wrote:Yep, I've priced about 50 of them. And I've found myself fine with it, unless I come across an S30 (which I'll still build up the engine or replace it) I'm going with a more race proven engine...and I still want a 6cyl.
the VG is far mroe race proven tahn the RB at least in the states ti is, can't say on a global scalsbut I suspect it's mreo proven globally as well as it's found in more chassis and the V6 offers a mroe favorable weight distributionand the L6 has more race pedigree than the rb and the vg put together
AZ-ZBum
I love how he's priced about 50 of them, but won't say the range or sites he's found them on. I also love how he has to make a billion posts in a row since he's so ADHD he can't get all his thoughts together before hitting the submit button.
4AM
AZ-ZBum wrote:I love how he's priced about 50 of them, but won't say the range or sites he's found them on. I also love how he has to make a billion posts in a row since he's so ADHD he can't get all his thoughts together before hitting the submit button.
Did you ask that? Where? "cause I flippin missed it!..oh, my thread; post when I like... and if you look at the top, they individual comments and answers...a**.
Modified by 4AM at 12:04 AM 5/10/2009
4AM
evildky wrote:the VG is far mroe race proven tahn the RB at least in the states ti is, can't say on a global scalsbut I suspect it's mreo proven globally as well as it's found in more chassis and the V6 offers a mroe favorable weight distributionand the L6 has more race pedigree than the rb and the vg put together
The Ls...inline isn't it? I like that. Were the engines cabeurator then? I bet they're rare and alot has to be changed to bring her up todate. But I have not looked into it. I am though, it would certainly be more "Z" and have lots of engine compartment room. Where the Ls tall? U know the hood.
Modified by 4AM at 12:06 AM 5/10/2009
evildky
06 Nissan 350Z GT
the L6 includes the L20A (not available in america), the L24 carbed int he 240Z, the L26, some came carbed most were injected) the L28 all injected, and the L28ET also injected, externally it's similar to the RM but with a smaller head due to being a single cam, the RB replaced the L6, the RB inherited the L6 cylinder bore spacing, the RB26 used the same stroke as the L24 with the engine bore fo the L28
and no they are not rare they last dang near forever the issue si the cccars rusted aroudn them, the 90's Z32 that ran in the SCCA GT2 class was powered by an L28ET do to diplacemtn limits of the class
but it's still a step backwards to put an inline 6 in the Z31 chassis, when the VG30ET has such great potential and is a factory offering in that chassis, these engines are capable of well north of 400 whp on stock internals
raremotive
The VH v-8 motors are race proven. SuperGT, Lemans series. All aluminum blocks. Way lighter, and higher torque than the rb series. They actually switched the tt rb with the na vh for better initial response around the apex..and every additional g you get the faster you are. Additionally it increased reliability of the race car on the track with fewer parts to fail.
These motors come with forged inners, unlike his older brother rb...
DJ Raijin
Car: 1992 300ZX 2+0 T Top NA
Rare_f8 wrote:The VH v-8 motors are race proven. SuperGT, Lemans series. All aluminum blocks. Way lighter, and higher torque than the rb series. They actually switched the tt rb with the na vh for better initial response around the apex..and every additional g you get the faster you are. Additionally it increased reliability of the race car on the track with fewer parts to fail.
Sweet, Glorious, Delicious VH45. I bet it feels great to have 200ft/lbs available at idle and a max of 320ft/lbs at your disposal without lag of any sort. Just pure powerband.
or get your jdm-tyte RB.
evildky
06 Nissan 350Z GT
the VH is more overengineered than the VG30DETT, how many VH swaps have you seen? and how many of them last mroe than a few thousand miles? if you want a VH, get a Q, they are cheaper than parts for the eigne anymore
AZ-ZBum
So how much can you get an RB26 for?
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
AZ-ZBum wrote:So how much can you get an RB26 for?
R32 RB26DETT motorset $3200RB25DET trany $1350
evildky
06 Nissan 350Z GT
for $4500 you can buy a running Z31T, and build it ro well north of 400 whp, you still ahve to fab the oil pan, buy or fab the mounts, fab the piping for ht intercooler and cooling, fab the criveshaft, work out the wiring and if you want anywhere near 400 whp it's gonna need new injectors, ecu and bigger turbo's, and at that point most opt for a fsingle turbo conversion that means a nes exhaust manifold and most also opt for a single tb conversion manifold
Return to “300ZX (Z31) Forum”
