edgartheace »
https://forums.nicoclub.com/edgartheace-u47896.html
Mon Aug 25, 2008 4:34 am
They are identical as far as internals go. They are different in respects to the exhause manifolds, PTU location, Engine harness layout, Injectors (most JDM 300zx engines still use the old pintle style prone to failure), AC compressor, Maybe PS pump if you have the HICAS model J, and the Balance tube. That's all I can think of off hand but it can go in you just need to swap some parts over.
