300ZX Electic Fan Conversion
qu1ks1lv3rmcd
Car: Nissan 300ZX
Just wondering if anyone has or knows how to swap the mechanical fan on a 1990+ 300ZX i'm looking for a step by step guide to swaping it out need help if you have pictures great kinda just need the a step by step tutorial
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
if you have to ask you should NOT do this!
qu1ks1lv3rmcd
Car: Nissan 300ZX
heyy man thanks for all the help really helped
xclusivez32
Car: 1990 300zx 2 seater limo
tt engine build
2004 gmc serria
i dont have any pictures but you need an electric thermostat and an electric fan that flows around the stock cfm's with a good shroud. the fan should come with a mounting kit, they are smiple plastic clips that push through the rad. then you wire in the thermostat that should come with a relay one wire goes to the ignition, 1 goes to the battery and a ground. on the other end there is a positive to the fan, negative to thermostat, a/c bypass, and a positive to thermostat. i put my relay and wires under the pass. side fender and ran them in with the wiring harness for a nice clean look. good luck
