300ZX 4-Piston Caliper Upgrade Problem....
REC
Car: 90 Q45 (100shot Nos - Nico Stage 3 Ecu)
I recently upgraded the calipers on my 90 Q45 with the 4 piston 300zx calipers. My brakes were working fine before but i wanted the increased performance. A member here named Wes told me that i could use the stock brake lines I just needed to shorten the brake line bolt to fit the caliper. After cutting off the heat shield and shortening the bolt me and a friend began to bleed the brakes and everything went as planned until i started the car. When the car isnt running there is plenty of pressure on the brake petal but as soon as the car is running the pedal is mushy and goes to the floor and doens't get any stiffer after pumping it several times. Obviously when driving around the parking lot there is literally no brakes at all as the pedal goes to the floor. I'm basically stuck and have no idea what the problem is. Has anyone experienced this before with this upgrade?
Q451990
It sounds like you still have air in the brake lines. I assume you bled the ABS actuator as well?
Heath
REC
How do you drain the ABS actuator?
goody90q45
Car: 1992 Infiniti Q45 (sold)
REC wrote:.....A member here named Wes told me that i could use the stock brake lines I just needed to shorten the brake line bolt to fit the caliper.
Wes who? j/k
JeromeS13
Car: 2008 Subaru Impreza STI
Are you sure you have the calipers on the correct side? If not, it is impossible to bleed correctly. Make sure the bleeder valve is at the top of the caliper.
-Jerome
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
JeromeS13 wrote:Are you sure you have the calipers on the correct side? If not, it is impossible to bleed correctly. Make sure the bleeder valve is at the top of the caliper.
-Jerome
Who is this wes character? I bet hes got a Q that looks like hell but also runs like hell on the track
