I want to let everyone know that the car is still coming along (pretty slowly though haha). Here's a progress report: I pulled out the ABS module (which weighed 16.5 lbs, not including the extra lines and fluid) and I am now bending my own brake lines.
I am about 90% sure that the way I'm doing it in this picture will work. If not, I will have to buy a whole new chassis and use the ABS system from the factory
Also, the rear main seal on the engine is leaking, so I will be removing the transmission and clutch to replace it. Then I will be pulling out the engine, replacing my cut crossmember with a new one, cutting more out of the oil pan, dropping the engine back in, and then installing an Accusump Oil Accumulator to make up for the lost oil capacity.
FInally, there's a bit more wiring to be done, and then a couple more things to patch up with the power steering removal, and then it will be on the road.
