WaddleDee72 »
https://forums.nicoclub.com/waddledee72-u219556.html
Thu Dec 05, 2013 3:00 pm
^Haha, yeah, DjMdubb, you can't just slap a turbo on; you have to buy a turbo, buy an intercooler, either buy or make a new exhaust manifold, redo the intake system, make oil lines into the turbo, and get a new ECU and program that; it's a lot of work. It would have been much easier for you to have bought a 2JZ-GTE that already has turbos on it.
Anyways, I was going to post a parts list with cost and everything once the project was completely finished, but, since you asked, I'll post the parts list as it stands right now.
$1730 1991 Nissan Fairlady Z Twin Turbo
$2099 Toyota 2JZ-GTE engine
$ 803 Toyota R154 transmission
$ 400 Freed Engineering 1JZ/2JZ mounting brackets
$ 429 Stage 2 clutch
$ 359 Lightweight flywheel
$ 159 UDSM 2JZ Water Pump
$ 114 Aluminum lightweight pulleys
$ 166 Clutch fork, clutch fork spring, support, and bolts
$ 78 Clutch release hub kit
$2995 ProEFI Pro128 ECU with sensors
$ 373 drive belt tensioner and damper for manual transmission
$ 40 Serpentine tensioner pulley & shorter belt (need for PS and A/C removal)
$ 228 Cusco SR20/180SX engine mounts
$ 21 2JZ thermostat
$ 60 stainless steel hardline and nuts for making custom brake lines
$ 46 oil cooler sandwich adapter
$ 175 Godspeed intercooler
$ 50 oil cooler radiator
$ 175 Driftworks HICAS Eliminator kit
Combined Shipping cost: $788
Total Cost so far: $11,288
I still need to buy wheels, an electric fan, a custom driveshaft, a blow-off valve, intake and exhaust pipes, and a ton of other stuff. There are always more unexpected costs. Needless to say, this is not a project to do if you're on a tight budget.
