I have the AEM, and while the most expensive, I have no complaints. Great noticeable sound. I can't speak for the others.
However, keep in mind with our engines, there are numerous cases where an aftermarket intake actually reduced whp because of the factory ECU tune. Quick google search will back it up. Most of the articles are for the 350z and Infiniti G35. Nevertheless, I don't see how our's would be an exception. Now if you retune the ECU, you can get a noticeable gain. See this article for example:
http://www.importtuner.com/tec....html
Now, where I have not had my ECU retuned as of yet, I didn't feel a difference when I added the AEM intake. But, I did noticed my RPM's jump up faster, which should also mean it added some ponies even if I can't feel it. Just keep in mind this is all anecdotal until someone reputable hits up a dyno with before and after. Other than the manufacturer's that is.
