280z Turbo motor swap
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
3wheelin720
Car: 1984 Nissan/Datsun 720 King Cab 4x4
Hey I was curious if anyone has ever tried an inline 6 turbo motor out of a 280z for a 720. Just found a motor and thought that could be interesting....potentially a lot of work since it's a long motor, but I thought I'd throw it out there and see....I might try it if it is realistic at all.
woodbutcher5691
Car: 85 720 2wd 5sp.
3- 280zx's
It has been done but it involves a lot of work. As in cutting out the center of the firewall and moving it back. Fabbing custom mounts an so on. I'd like to do it one of these days but I want to have an enclosed shop to rip my truck apart in. :cool:
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Its not necessary to cut the firewall. Set up the engine in the bay to see if the radiator will fit in the bat or if it needs to go on the outside with the electric fans. Then make the mounts.
woodbutcher5691
3- 280zx's
flinterman2000 wrote:Its not necessary to cut the firewall. Set up the engine in the bay to see if the radiator will fit in the bat or if it needs to go on the outside with the electric fans. Then make the mounts.
That's doable but I want mine to look unmolested as in "sleeper" :chuckle: It's alot of motor for a short space. I dream on about it all the time, one of these days, one of these days. :crazy:
Return to “Datsun 720”
