240sx Wont Start...sometimes
boogerdawg
Car: 1992 Nissan 240sx.
Hey guys, just bought a 92 hatch with manual transmission and I drove it home, turned it off, and now it wont start. Whats up with that? The motor turns over but just wont fire up. Any ideas? Thanks
Florida240sx
Battery/ battery connection
boogerdawg
Battery connections are tight. The car runs fine when it DOES start. but it has its fits where all it wants to do is sit there and crank over but not actually start up. any other ideas?
boogerdawg
Well the car started this morning. Then i turned it off and now it wont come back on. Same symptoms, wants to start but just wont.....i had disconnected the battery overnight and it started up no problem this morning. so could it be an ecu related problem or what? Thanks
DevilMB3017
Was it always a manual? Maybe something as simple as the clutch safety switch thing?
boogerdawg
Yes, the car has always been a 5 speed...this really has me stumped.
WDRacing
Is it a turbo?
boogerdawg
Nope. No turbo yet.
boogerdawg
Sorry guys, didnt realize i posted in the turbo forum. But do you guys have any suggestions?
WDRacing
Moved
CourtesyBullet
Car: 91 240sx Hatch
You know, when I put the engine in my car it wouldn't start, which turned out to be due to a loose ground on the alternator. A couple days later it happend again and I fixed it again, It's been good ever since. So while it may not be that one, just check all your grounds.
boogerdawg
Okay so i still havent fixed this but I have a question. If the timing was off, would my car run fine and just have problems starting?
