240sx help please.
1991ls13
Car: s13 ls1 hatch
Hello.I hope you can help me with my problem. here is all the info possible.
Make: NissanYear:1991Model:240sx LE
Engine:180200 ka24de with 5 speed(everything is stock)
The check engine light is on but i have no idea why. I don`t really hear or feel anything wrong. It is not my spark plugs cause it starts right up, stays at idle and eveything.
Here is the maintenance done in the last few months.......oil change about 650 miles ago.Tune up about a little over a year, and a bunch of other things but its been a years +.
The only thing that i can think of(but it might be my imagination) that seems like it might be wrong is it seems like its not getting the gas mileage it should be getting and once in a while i think i smell gas.
If i need more info please tell me and i`ll be more then happy to put it up.
Thank you for your help and its much appreciated.
s13_chris
Car: 90 240sx Hatch
Use the search button at the top of the page and look for ECU Diagnostic, or Checking ECU, ECU Codes. Something along those lines. The search button is your friend. A writeup should show up telling you how to check your ECU and see what code you have. Try it out and let us know.
1991ls13
Car: s13 ls1 hatch
thanks for the infoand i know about the search buttonbut i didnt know it was even my ecu i should search for
fun240
Car: 95' S14, 91' NX1600
Could be tons of things bro.
Pretty much its a sensor tho. You definitly should get a OBDI tester and see whats up with it.
1991ls13
Car: s13 ls1 hatch
where would i get one and for how much? thanks for your help
slow40
Car: S13
pull your code first, no need to buy anything. get a screwdriver and take off the passenger floor kickpanel, like 2 or 3 screws, and your plastic door trim that is at the base of the carpet. behind that kick panel you will find your ecu. take it off using a 10 mm socket. flip it around and you will see a little round knob. to check your codes, turn your switch from the off position to the on position (running position, not cranking), a little led light will come on on the ecu. within a couple of seconds, take a flat head and turn the knob fully clockwise, then fully counterclockwise, then your led light will start flashing. watch it and note how many long flashes then short flashes happen. for example long, long, long, long, long, short short short short short would be 55. maybe more than one, but it will repeat itself after all are done. post it up and see what you get.
1991ls13
Car: s13 ls1 hatch
thank you extremely. its super late right now just got back from a trip so ill be doing this tomorrow and ill post up and lets you know whats going on.thank you much again
vancouverbc
Car: 1991 240sx
california computers are different. these are the codes that trigger red light in dash. a non california only triggers red light in dash for two codes.
look up ecu in tutorial link in signature. or google 240sx ecu code tutorial or whatever problem you have re 240sx.
For California Models Only:
Code # Description
12 Air flow meter circuit13 Engine temperature sensor circuit14 Vehicle speed sensor circuit31 E.C.U. (E.C.C.S. control unit)32 EGR function33 Exhaust gas O2 sensor circuit35 Exhaust gas temperature circuit43 Throttle position sensor circuit45 Injector leak
Modified by vancouverbc at 10:04 AM 10/13/2008
1991ls13
Car: s13 ls1 hatch
going to check it out now, thank you for more help.it is so much appreciated.
1991ls13
Car: s13 ls1 hatch
alright finally i got to it doin it correctly and its 33....?3 long and 3 short flashes. ill check some stuff out to see what it is.i cant say thank you enough for the help
1991ls13
Car: s13 ls1 hatch
looks like its the Exhaust gas O2 sensor circuit. just reread my thread, thank you for the info.
1991ls13
Car: s13 ls1 hatch
well **** i guess autozone told me there is o2 senors before and after the cadillac converter. so i dont know how to figure witch one it is
1991ls13
Car: s13 ls1 hatch
never mind, only one. 96 and up has two, well at least thats what the guy said at autozone
1991ls13
Car: s13 ls1 hatch
done and fixed thank you for your help once again. specaily since when i called a shop they said it would be 110 just to see what it was and its not a for sure thing they`d find out what it was.
saving me alot of money in my book
THANK YOU!!!!
