VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Mon Jun 16, 2025 4:10 pm
They should be wedge T10's. However, be exquisitely careful when messing with the interior lamps. The "fade" effects are accomplished by an open-collector tran-sistor driver inside the BCM, and if you accidentally short a bulb socket while the lights are on, it will trash the BCM. I strongly recommend disconnecting the battery while messing with bulbs you aren't sure about.
