Swapping 2nd gen Rogue head units to get latest features
mustang65dan
Car: 2015 Nissan Rogue
I would like to take out the stock radio and replace with Nissan part 259154BA0A with satellite radio. Does anyone know what cables will need to be changed or where I can get the connector pin out information?
Reason: Revise Title
PapaSmurf2k3
Site Admin
The connector pin out info should be available in the factory service manual.
http://www.nicoclub.com/FSM
I'm not sure if the harnesses for the 2 different radios are the same either. I'm sure you could get it to work though.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2012 Honda CR-V LX
2022 Honda Pilot Special Edition
2015 AV info http://www.nicoclub.com/FSM/Rogue/2015%20Rogue/av.pdf
Please know that if your intention is to upgrade with the hope of getting navigation, you'll need more than just the head unit. I believe amongst other things, you'll need to replace the external antenna on the rear of the vehicle as well. On the plus side, it now appears that the satellite receiver is built into the head unit. On first gen Rogues, it's a separate component.
Btomlin
Car: 2015 Nissan Rogue Sv (US)
I have a 2015 Rogue SV with the standard SV non-navigation radio head. Is it possible to buy an oem navigation head and upgrade to that?
Do I need more than just the module?
Reason: Threads merged
Rogue One
2012 Honda CR-V LX
No, it's not that simple. The NAV is just a display unit. There are several other parts, including a separate receiver for the sat signal. It would be cheaper and Far easier to get a standalone unit (which would be more accurate and have free updates).
This was discussed before. SEARCH currently down, so I'll merge it when it's working again.
joeyfwb.fl
Hi, I'm new here, first post. Just bought a 2016 Nissan Rogue SV with premium package. Prior to buying that, I was considering trims with no nav and was wondering the same thing (if I could upgrade the stock radio with no nav myself). I didn't get too far into researching, but if Rogue One is correct about you also needing a separate receiver for the upgrade, IMO it's not worth the hassle.
I did come across this however and looks pretty good: https://www.youtube.com/watch?v=HTcScYB1224. You probably get more functionality and versatility since it's android. Nissan Connect Apps are a joke and shouldn't even be listed as a feature. One thing I didn't like about that unit is the boot up time ... 30 seconds. Seems long but I guess you could get used to it.
Rogue One
2012 Honda CR-V LX
For what it's worth, here's my 2¢. Even IF the factory head unit now contains the satellite receiver built in, AFAIK you'll still need the other components to make it work properly. Additionally the yearly map updates are not free, and although they can be obtained on sale for $99, why pay for the added expense (not to mention the negative reviews the NAV system gets in the forums)? Oh, and there's the sound quality issue as well.
I'd opt for a replacement unit from a company like Pioneer, JBL or Kenwood. Sure you could go with a Chinese unit, but what you save in price, you'll sacrifice in sound quality and functionality (slow boot times, etc.). On a related note, the manufacturer of the unit in the youtube clip also makes a unit that's compatible with the around view camera system.
If you still want to look into getting the OEM NAV unit, it's available on eBay, but I'd check with the service department at your local Nissan dealership to find out exactly what you'll need to make it work.
mustang65dan
the navigation unit has different wiring connections then the standard unit the gps ant is the only other thing needed but the wiring has to be changed into different connectors. If you read the connections it is spreed across several different pages in the wiring diagrams I have not be able to located the 2014 connectors as this starts a new style. still trying when i get the time
jateshk
I have a 2016 Nissan Rogue S. THis is what my stereo look like:
Can i upgrade to a OEM NAV from ebay? Is itplug and play? Has anyone does this before? EBay selling for $200 for oem nav.
Reason: Merged with existing thread
Rogue One
2012 Honda CR-V LX
jateshk wrote:I have a 2016 Nissan Rogue S. THis is what my stereo look like:
We have an incredible SEARCH feature on this forum. Merged with existing thread. Please read the previous posts on this subject. You should also search for info on the poor functionality and lack of updates for the OEM GPS unit. The consensus is it sucks.
:poke: --------> READ BEFORE CREATING NEW THREAD! <--------
jateshk
sorry about that.
So as i read this does this mean it wont work?
Meaning if i buy the ebay unit and buy an enternal antenna it wont work? Has anyone tried?
I have done this in other cars and has been plug and play but not sure if anyone with a 2016 has done it? The nav unit is only selling for $200!
Rogue One
2012 Honda CR-V LX
Well, here's an image of the back of your radio:
And this is the backside of the one you want to get off eBay:
jateshk
lol. thanks for that. i guess not then. Oh well.
Rogue One
2012 Honda CR-V LX
There's one other thing to take into account (it slipped my mind earlier). I don't believe the unit you were looking at included the SD map card. Currently there's an outdated one on eBay for US $47.99. The most current map is on sale for US $99.
gtcdma
Car: 2012 Xterra Pro-4X
Hi! Is anyone here still interested in the OEM nav upgrade for 2014-2016 Rogue? I have a solution for you.
ja231
Car: Rogue
Yes. I am interested.
gtcdma
ja231 wrote:
Tue Dec 19, 2017 4:38 pm
I'm selling OEM navigation upgrade kits for the Rogue, Altima and Titan on eBay. PMed you a link.
It's easy to install and works right away like it came with navigation from factory, except Nissan Connect smartphone app, but it's possible to get it to work as well.
auto1001
Car: 2017 Nissan Rogue S
gtcdma wrote:
Wed Dec 20, 2017 8:48 am
What is the link to your product?
gtcdma
auto1001 wrote:
Sun Dec 24, 2017 9:49 pm
Here : https://www.ebay.com/sch/gt_kiev/m.html ... pg=&_from=
stalin
Car: 2016 Nissan Rogue OEM Factory Navigation Upgrade Kit hardness
I need to buy the harness 2nd gen Rogue radio upgrade to factory Nissan satellite radio. Please let me know if you can help me. Thanks.
stalin
Hello,
Yes i am very interested in buying 2nd gen Rogue radio upgrade to factory Nissan satellite radio, please send me a message to [email protected] asap, thanks
mikeross11
Car: 2018 Altima
2015 Rogue
2018 Sentra
2012 Sentra SR
Hello do you still have this adapters? I bought that radio on ebay and need this harness, thanks
mikeross11
Car: 2018 Altima
2015 Rogue
2018 Sentra
2012 Sentra SR
gtcdma wrote:
Sun Dec 03, 2017 4:20 pm
I do, do you still have them, please send me link where to buy
thank you very much
kasilva
Car: Nissan Rogue 2nd Generation
Hi, I am looking to upgrade my Rogue OEM radio to the SV navigation radio. I am interested. Send me a message. Thanks
Gone_Rogue_727
Hello all,
Looking to upgrade my 2015 Rogue S Radio with Sirius XM to a Navigation Radio with Sirius XM... I found one on eBay, but will I need any additional parts since my car originally does not come equipped with Navi? And on the eBay listing, the seller mentioned they do not provide Radio Codes? Do I use the radio code that was given to me with my car and if not, where and how much do I have to pay to get one?
dubnationd
Car: 2015 Rogue
i have experience with Volkswagen with VW if you were installing a different OEM head-unit and you did not have the codes you had to contact the dealer the charge was around 50 dollars. i was told that you would need to get the firmware update as well to get it to work properly.
Rogue One
2012 Honda CR-V LX
3. LIST YOUR YEAR, MODEL, ETC: Give us as much info as possible. Members are not mind readers, nor do they have time to dig for answers.
There are differences between the model years, so without knowing the exact year and trim of your car, we can't provide accurate info to answer your questions.
jb9898
I'm looking to buy this connector for my radio. Please send me link or instructions on how to get this.
mikeross11
Car: 2018 Altima
2015 Rogue
2018 Sentra
2012 Sentra SR
If anyone ever have this adapter I will be happy to buy it as it seams to be no way to install reoplace the navigation radio :( thank you very much for replies
kingxavier24
Hey there everyone! I have a 2016 Rogue SV with the factory Navigation and the 360 birds eye camera. I am wanting to replace the head unit with one from a 2018 so I can get the extra features and carplay etc.
I have looked everywhere and can not find this being done. I do know that the Harness is bigger in the 2018 and can not find that harness on the internet anywhere.
I am wondering if this is something that can be done and if anyone else on here has attempted to do this.
Thanks!
Reason: Topics merged
Return to “Rogue Forum”
