2019 Rogue IPDM pin chart question
hotrodjohn71
Car: 2010 Nissan Rogue
If you have access to the electrical manual for the 2019 Nissan Rogue, can you tell me which wire (color) and which pin # in the IPDM sends the charge signal to the alternator?
This will be the single wire that the IPDM uses to send signals from the VVCS (variable voltage control system) to the alternator to control charge voltage.
Thanks
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I answered your other post, there's no cuttable wire. The '17~'20 gen2's and all the gen3's have LAN alternators wired to the ECM, not PWM alternators wired to the IPDM like earlier models.
hotrodjohn71
Thank you. I appreciate your help.
Sigster
If it's about disabling 'smart' charging,
I cut the pink wire for the current sensor on our 2018 Rogue and that did the trick,
now behaves like the 'dumber' chargers of old
VStar650CL
Technical Expert
Sigster wrote:
Thu Nov 20, 2025 11:08 am
Yep, that's what he wants to do, but there's actually no need to cut anything. Pulling the connector to the Current Sensor per the OP's other post will serve the same purpose.
Sigster
VStar650CL wrote:
Thu Nov 20, 2025 3:29 pm
I left the connector on to still have the temperature sensor connected,
assuming that the temperature compensation still works even with the current sensor gone.
Which is just a hope or guess...
VStar650CL
Technical Expert
Old school vehicles had neither current nor battery temperature sensors because they didn't need them. The not-so-smart smart charge is what makes both necessary, but that only exists in a questionable effort to save a couple tenths of a mile per gallon at the cost of trashing batteries when it malfunctions. You don't need either one.
Return to “Rogue Forum”
